Author Topic: Keycaps puller for Model M's  (Read 2217 times)
Offline codek
« on: Sat, 13 November 2010, 01:58:49 »
Do I need one?
Where can I find one cheap with cheap shipping.  If someone could find something on Amazon that would be great.
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #1 on: Sat, 13 November 2010, 02:46:59 »
I've never used one.  They come off pretty easily.  the handle end of a spoon works for me.
I <3 BS
Offline Cheese101
« Reply #3 on: Sat, 13 November 2010, 05:59:12 »
you don't need one they come off easy
Main:
IBM Model M 1391401 ; 4th October 1991
Spare:
IBM kb-8923 ; 1996 - owned from new!
Offline chongyixiong
« Reply #4 on: Sat, 13 November 2010, 06:20:27 »
Don't waste money on one.. it's really really simple.
Just pull up that's all.. if you have 2-piece keycaps, you might want to remove the upper piece first but I usually just yank both of them out together.
Offline Pylon
« Reply #5 on: Sat, 13 November 2010, 07:04:06 »
2-pieces come off really easily.
Offline NewbieOneKenobi
« Reply #6 on: Sat, 13 November 2010, 15:05:54 »
Use a thin screwdriver for leverage.
