Author Topic: rough travel normal for a Filco?  (Read 3141 times)
Offline wordfool
« on: Wed, 17 November 2010, 19:49:03 »
Just got a Filco tenkeyless with cherry browns and I love typing on the thing but I couldn't help but notice that when I press keys slowly the first 25% or so of the travel is rough and has a lot of friction stickiness. I presume this is normal, but just wanted to check. Also curious if it smooths out over time.
Filco TKL and Minila Air (browns) the daily drivers. Black M13 gathering dust. Former Realforce 103U afficionado
Offline MyNameIsDan
« Reply #1 on: Wed, 17 November 2010, 22:01:04 »
Were you referring to pressure point as shown in this force diagram? If so then yes, the first few mm of travel requires higher force, then easy throughout. Or is it actually sticky feeling?
Current Keyboard: Filco Majestouch 104 Browns (FKBN104M/EB)
Current Mice: Steelseries Xai (1400cc//800cc) on Steelseries 9HD.
Anyone want to donate me a keycap remover? <3
Offline msiegel
« Reply #2 on: Wed, 17 November 2010, 22:27:06 »
hmm, i feel what you're describing. and it feels exactly the way the diagram looks.
ripster, did you actually lose the bump over time?
Offline WhiteRice
« Reply #3 on: Wed, 17 November 2010, 22:29:01 »
Quote from: wordfool;248353
Are you talking about the tactile bump, or the travel before that point?
Offline wordfool
« Reply #4 on: Wed, 17 November 2010, 22:34:21 »
as I put pressure on a key and slowly increase it feels like plastic on plastic friction... kinda rough and slightly jerky for a few mm until it caves and lightens up. So yes, a tactile bump, but it's a rough bump, not a smooth one
Offline wanabe
« Reply #5 on: Wed, 17 November 2010, 22:39:32 »
i just got my filco brown, its the same.  my H key is particularly scratchy, but it's not really noticeable in normal use
Offline jaynoon
« Reply #6 on: Thu, 18 November 2010, 00:04:03 »
Yeah, my new Filco Brown has a similar slight roughness, up-to and through the tactile bump. Below that it feels more smooth, but maybe just because there is so little resistance.
It doesn't really bother me, and since it feels like rubbing of some sort, I feel like time will probably smooth it out like ripster suggests.
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline sapht
    • http://sapht.com/
« Reply #7 on: Thu, 18 November 2010, 03:22:00 »
When I first got my browns (filco majestouch tenkeyless) I bottomed out at every keystroke and couldn't figure out how not to do that. It really felt unpredictable and way too heavy until the "bump". Now, a years usage later, I bottom out about 50% of the time. I'm unsure if it's because I've committed the force curve to muscle memory, or the switches actually got smoother. I never really imagined it could be the latter.
Current hoard: Filco Majestouch Tenkeyless Brown, Das Keyboard II Professional Blue, IBM Model M double shot keycaps, HHKB2 blank white
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #8 on: Thu, 18 November 2010, 03:34:40 »
To the OP-
Yes indeedy it's normal, some exhibit it (slight roughness) more than others and it should smooth out slightly over time.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline ClackHead
« Reply #9 on: Thu, 18 November 2010, 05:42:34 »
Just echoing what others have already said. I noticed the same thing when I got my Filco with cherry blues a couple months ago.
It has gotten much smoother now and it will only get better.
Filco Majestouch TKL MXBlue
