Author Topic: Keytweak on Windows7  (Read 7469 times)
Offline 2084
« on: Fri, 19 November 2010, 08:48:39 »
Is anyone running KeyTweak on Windows7?
I'm getting an error right after install:
"Run-time error '9':
Subscript out of range"
Google didn't find any good pages besides something on kbdmania which didn't make sense with googletranslate
Does anyone know a solution?
Offline 2084
« Reply #1 on: Fri, 19 November 2010, 09:43:03 »
Tried version 2.3 and 2.2 both give me the same error.
Doesn't work in XP compability mode either.
« Last Edit: Fri, 19 November 2010, 09:54:43 by 2084 »
Offline Rajagra
« Reply #2 on: Fri, 19 November 2010, 11:20:54 »
The splash screen for 2.3.0 says it's for NT/2000/XP/Vista/Win 7.
Are you running it as administrator?
Offline 2084
« Reply #3 on: Fri, 19 November 2010, 11:25:40 »
Quote from: Rajagra;249185
Yes it even prompts me to run as administrator by default. But I tried another tool "Key Mapper" and it works fine for me.
Mapped Scroll Lock and Pause to Volume Down/Up and Caps Lock to Ctrl
