Author Topic: Broken Siig Minitouch KB-1903  (Read 5404 times)
Offline elbowglue
« on: Fri, 19 November 2010, 15:37:43 »
http://cgi.ebay.com/SIIG-Model-1903-MiniTouch-Enhanced-Keyboard-/260695486487?pt=PCA_Mice_Trackballs&hash=item3cb2a97017#ht_500wt_950
Good for keycaps for those of you who have the GHSS.  I had asked this seller earlier, he said this was made in China, so it is probably white clicky alps.  However the RJ-11 connector makes me think it could potentially be monterey switches?
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline chimera15
« Reply #1 on: Fri, 19 November 2010, 15:59:26 »
Awesome find, thanks.  Wish it was bin.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline TexasFlood
« Reply #2 on: Fri, 19 November 2010, 16:05:17 »
Quote from: chimera15;249427
Me to since it might end up going for a silly price even broken.
Offline TexasFlood
« Reply #3 on: Fri, 26 November 2010, 14:32:28 »
Sold for $31 + $10 shipping.  Bit of a gamble but good deal if easily fixed.
Offline Soarer
« Reply #4 on: Fri, 26 November 2010, 14:49:35 »
Quote from: ripster;252616
Do all the Minitouches have that RJ11 connector on the back?  That was for a numpad IIRC.
Nope. But... on mine you can see the outline of where the hole would be. Same mould I guess, but with options.
Offline didjamatic
« Reply #5 on: Fri, 26 November 2010, 16:08:21 »
Montereys:
Blue letters on sides of keys for numpad layer and some of the other key printing is blue.
Made in Taiwan
ALPS:
Gray letters on sides of keys for numpad layer
Made in China
Some Minitouch models have RJ11/12 some don't.  Some have DB-15 serial connector.  I believe either connector can be used for a barcode scanner or I suppose a numpad.  Since these devices input text like a keyboard does, you can have them use the same parent interface as the keyboard (the AT/PS2 connector) it definitely couldn't be a mouse because that would require it's own connection to the PC (unless using USB which in this case you wouldn't be)
Offline elbowglue
« Reply #6 on: Fri, 26 November 2010, 17:15:26 »
Quote from: didjamatic;252685
Montereys:
Made in Taiwan
ALPS:
Made in China
Whats odd is the Monterey Minitouch I got from aegroratio dosen't have any blue lettering on the keys.  It is made in Taiwan however, which in my opinion is the most reliable way of telling them apart.
My monterey minitouch has an RJ11 connector.  I wonder if i could daisy chain a dolch keyboard onto it, use it as an expensive dolch to AT adapter..
Offline elbowglue
« Reply #7 on: Fri, 26 November 2010, 17:18:32 »
And I don't envy webwit for finding great cheap deals on rare keyboards.  Not one bit.
Offline elbowglue
« Reply #8 on: Fri, 26 November 2010, 17:24:59 »
He probably did.
I won the imbecile world championships to get mine.
Offline didjamatic
« Reply #9 on: Fri, 26 November 2010, 19:14:11 »
Dang, i thought the blue lettering was fail-safe on identifying Montereys.  I still think it's generally correct, but apparently there was some crossover.
I tried daisy chaining an ADB keyboard off of a Northgate UltraPlus that has PS/2 and ADB connectors on it, but no dice.  I had to buy a Griffin Imate.
Offline Infinite north
« Reply #10 on: Fri, 26 November 2010, 21:54:33 »
So you don't envy him on picking up a fingerworks touchstream for $27 bucks a few months back? it's good to know that I am not the only one who doesn"t envy things like that.
Offline ricercar
  • mostly abides
« Reply #11 on: Sat, 27 November 2010, 14:03:19 »
I decided to pick up the OP board. $31 gives me a chance to dye the keys without ruining my primary Minitouch.
Maybe with the whole board in GeekHack green won't be a headache to type on a SiiG Minitouch. With only G and H green, the color of my migraine aura, typing on a Minitouch feels like my blind spot is in the center of the board and it's really unpleasant.
Offline aegrotatio
« Reply #12 on: Sat, 27 November 2010, 23:29:51 »
SIIG always felt, to me, like a reckless reseller or reckless OEM.  You can't really know from Monterey or regular ALPS on these things.  Even the recent BTC-5xxx keyboards and stuff, different feel, different keyboards, same model number.  Ugh.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline ricercar
  • mostly abides
« Reply #13 on: Tue, 30 November 2010, 17:59:41 »
I always thought that if your SiiG was broken you'd have to go into preferences to fix it.
<-- preferring that my broken SiiG arrives sooner, rather than later
Offline ricercar
  • mostly abides
« Reply #14 on: Tue, 07 December 2010, 18:53:26 »
The $30 broken MiniTouch isn't working--through a blue cube it's an unrecognized USB device, which I find very interesting. Upon opening it up, the plate is bent; from the bend angle it was likely dropped on the front left corner from a significant height. There's no visible damage to the PCB or solder joints.
The RJ11 is not connected inside the case. Matter of fact, the RJ11 jack doesn't even have the metal wires installed, and there are NO PADS inside the case to which one might assume a number pad was attached. It appears that the RJ11 was intended as a removable cable for the MiniTouch itself, since the only thing within a solder splash of the empty RJ11 jack is the jack for the AT cable to attach.
I've harvested the key caps. I'm likely to harvest the switches when I have an afternoon full of patience and motivation. If anyone has need of SiiG MiniTouch key caps or a MiniTouch case, let me know in PM.
Offline chimera15
« Reply #15 on: Tue, 07 December 2010, 20:16:34 »
Um, so... wait... Did it turn out to be a Monterey?  I didn't bid cause I wasn't sure. Are you going to sell the plate/pcb?  It's a Monterey version?  I can probably fix it with a standard one even if the chip is dead, as I have replacement parts I would fix a Monterey with.  I'll buy the thing from you.
Don't destroy it if it's a Monterey, it's a loss to the keyboard community for sure.  Sell it to someone who can fix it if you can't.
« Last Edit: Tue, 07 December 2010, 20:26:56 by chimera15 »
Alps boards:
Offline ricercar
  • mostly abides
« Reply #16 on: Tue, 07 December 2010, 21:41:55 »
During the auction I asked the seller <<China or [strike]Taiwan[/strike]>>, so I knew it was complicated whites.
If you're serious about wanting the PCB/switches, Chimera, PM me? Harvesting the switches is not high on my to-do list, so offer me $20+ shipping (probably $3) and it's yours.
Offline chimera15
« Reply #17 on: Tue, 07 December 2010, 22:44:59 »
Ah so it's alps?  $20?  I'll take it.  I can use the case/plate to fix my pcb which is without one because I used it to make a wireless one, even if I can't fix it.
Alps boards:
