Author Topic: Switch in SIIG JKAB0211?  (Read 2873 times)
Offline CeeSA
« on: Mon, 22 November 2010, 05:57:22 »
anyone know the switches inside the SIIG JKAB0211:
http://cgi.ebay.com/SIIG-JKAB0211-80-key-minitouch-plus-enhanced-keyboard-/190446909477?pt=PCA_Mice_Trackballs&hash=item2c57853825
Homepage from SIIG does not give that info.
thanks
Offline Half-Saint
« Reply #1 on: Mon, 22 November 2010, 06:36:16 »
I think it's a rubber dome...
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline sixty
    • http://deskthority.net
« Reply #2 on: Mon, 22 November 2010, 07:13:27 »
Yeah, all the modern SIIGs minis are rubber domes. The old ones (minitouch series) are ALPS.
Offline CeeSA
« Reply #3 on: Mon, 22 November 2010, 09:41:48 »
i think this is not a new one.
it comes whith DIN connector.
in the description:
- Switch mechanism: Mechanical-key switch
and
- High-quality key switches for the "click" and "feel" that typists prefer
But what Mechanical-key switch?
Offline TexasFlood
« Reply #4 on: Mon, 22 November 2010, 10:05:45 »
Text can be misleading. Have the seller pull a key and take a picture of what's underneath to be sure.
Offline Necroleachate
« Reply #5 on: Mon, 22 November 2010, 14:46:28 »
I can say for sure it's not mechanical because I own one.
It's rubber dome under plastic hammers. It has decent stiffness and tactility for a rubber dome but still rubber.
Any Siig Minitouch (Plus) or BTC 5100 with arrow keys arranged as an inverted L is the dome version. Another difference are the square function row keys. On the alps version they're rectangular.
[SIGPIC][/SIGPIC]
