Author Topic: My Model M has just arrived  (Read 5195 times)
Offline patrickgeekhack
« on: Tue, 23 November 2010, 10:11:56 »
I got it from ncbound10.
First impressions:
The Good
- I love the sound better than the Customizer
- Arrived fast
The Bad
- Cleaning job is not the best one
- Packaging was scarry. Let's just say it not protected in a good way.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline kidchunks
« Reply #1 on: Tue, 23 November 2010, 10:15:25 »
Enjoy that model M
I've got some cleaning to do to mine. May just do it once my other keyboards arrive.
Topre || BS > *
my root : kidchunks[dot]com
« Reply #2 on: Tue, 23 November 2010, 10:17:46 »
Quote from: ripster;251181
NCBound10 is a pretty mediocre Ebay seller.  I dislike the way he tints his pics blue.
That said, I did get an AEKII from him that was non-yellowed.
Talking about yellowing. Why do Model Ms don't become that yellow?
Quote from: kidchunks;251183
Enjoy that model M
Thanks.
« Reply #3 on: Tue, 23 November 2010, 10:27:56 »
I have to test mine  a bit. Excel 2010 is printing some dots above my letters.
Offline kidchunks
« Reply #4 on: Tue, 23 November 2010, 10:30:44 »
Quote from: ripster;251187
The yellowing all depends on the additives added to the plastic.  Bromides.
Almost all plastic in the end, modern or vintage, PBT or ABS,  will turn yellow or at least break down with enough UV exposure.
If no one has said it yet, you have a dope ass collection of legos!
Topre || BS > *
Offline MissileMike
« Reply #5 on: Tue, 23 November 2010, 10:48:20 »
It's not his camera.  Some pictures are tinted, some aren't.  Check out the mini he has up on ebay right now- not tinted at all.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #6 on: Tue, 23 November 2010, 11:10:20 »
I don't know if it's psychological, but the Model M (Lexmark) feels different from the Unicomp. The former has a more pinging noise, whereas the latter has a more clacky noise.
« Reply #7 on: Tue, 23 November 2010, 11:56:14 »
I thought every 1391401 came with a speaker. I cannot see one from the outside.
« Reply #8 on: Tue, 23 November 2010, 12:41:53 »
Quote from: kishy;251248
It's no psychological, the older boards tend to be pingier and "looser" feeling. I think it makes them feel better.
That's exactly my feeling right now.
Edit: nope, AFAIK no 1391401 came with a speaker. They all have the speaker grille, but no installed speaker. It was used for some RS/6000 version of the keyboard, and possibly a couple terminal varieties (??) but not the "PC" line units.
Thanks for the info.
Offline KillerBee
« Reply #9 on: Wed, 24 November 2010, 04:06:19 »
Quote from: patrickgeekhack;251245
The 51G8572 was the one that came with a speaker
http://geekhack.org/showthread.php?t=11983
IBM Model M 1386304 Nov. 1985
« Reply #10 on: Wed, 24 November 2010, 07:53:34 »
Quote from: KillerBee;251673
Good to know. I learn something new every time.
« Reply #11 on: Wed, 24 November 2010, 07:58:37 »
Quick video of my Model M. I know the lighting and camera angle are not good, but I had very little time to do this and my main goal was to get the sound as faithful as I could.
« Reply #12 on: Wed, 01 December 2010, 07:57:41 »
Is it normal for one of my CTRL key to be a single keycap? Same applies to Caps Lock?
Offline Arcanius
  • Buckling Spring Lover
« Reply #13 on: Wed, 01 December 2010, 16:05:26 »
Well my 1391401 (93, Blue label, Made by IBM) has one keycap for Caps lock, but has a two piece keycap for Ctrl and Alt.
Offline theferenc
« Reply #14 on: Wed, 01 December 2010, 16:12:48 »
All of mine are 2 piece, except for backspace, as far as I know. I didn't check capslock though. I'll do that tomorrow when I go in to work.
« Reply #15 on: Wed, 01 December 2010, 19:26:49 »
Mmm...My shift keys are single-piece keycaps.
« Reply #16 on: Thu, 02 December 2010, 07:44:03 »
I have a mixture of grey and white stems. I suspect the seller replaced them. Who knows? As long as the keyboard is working, I am fine. Unless the grey stems are for the grey colour keycaps. I did not check when I pulled my keys for cleaning.
EDIT: One thing I noticed recently is that the Model M seems to be slower when I have my Shift and down arrow keys held to select a bunch of messages in Outlook. The selection is much faster with the Das.
« Reply #17 on: Thu, 09 December 2010, 07:45:34 »
I have the impression that Model M keycaps become dirty quite fast.
