Author Topic: [FI] X-keys Professional (58 Keys) USB  (Read 3064 times)
Offline Ekaros
« on: Wed, 24 November 2010, 13:47:08 »
http://www.huuto.net/kohteet/x-keys-professional-58-keys-usb/157734455
Anyone have any idea about this one? Specs says something about MX tactile silent, probably browns?
50€+8.5 doesn't seem too bad?
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Ekaros
« Reply #1 on: Wed, 24 November 2010, 14:05:28 »
Quote from: ripster;251915
X-keys makes a Cherry Black version.  Not sure about that particular one.
http://www.xkeys.com/techdocs/specifications/spc.pro.usb.pdf
Spec sheet, if link is right...
[SIGPIC][/SIGPIC]
Offline PIE Amber
    • http://www.piengineering.com
« Reply #2 on: Wed, 01 December 2010, 15:48:49 »
Yep, the Pro uses Cherry Browns.
For what it's worth, the USB X-keys do indeed have memory on board, as listed in our spec sheet. I think what you're interested in is hardware mode.
Please let me know if you have any questions. Feel free to contact me directly (amberm@piengineering.com).
P.I. Engineering
Technical Support
tech@piengineering.com
517-655-5523, ex. 19
Offline Ekaros
« Reply #3 on: Fri, 03 December 2010, 07:45:36 »
Quote from: PIE Amber;255126
Went on and bidded on it, have to see.
I hope it can emulate "real" numpad...
[SIGPIC][/SIGPIC]
Offline PIE Amber
« Reply #4 on: Mon, 06 December 2010, 12:33:27 »
Assuming you're referring to sending the same scan codes as the normal numpad keys (and not just the ones that correspond to the top row numbers), yep we can do that.
P.I. Engineering
Technical Support
Offline Ekaros
« Reply #5 on: Wed, 08 December 2010, 13:08:26 »
Seems like I won it, have to see when it arrives and do I find some real use for it ;D
[SIGPIC][/SIGPIC]
Offline PIE Amber
« Reply #6 on: Fri, 10 December 2010, 05:38:34 »
Congratulations! Let me know if you need any help setting up.
P.I. Engineering
Technical Support
