Author Topic: Spark Help  (Read 1579 times)
Offline JLai
Spark Help
« on: Sat, 27 November 2010, 16:34:15 »
I just received my Filco Tenkeyless w/ Blue Cherries and I successfully remapped the volume keys.  The issue is that the volume change beep has disappeared.  I have the volume change beep enabled in the system preferences->sound.  I also tried to enable the volume beep change in Spark, except it seems that Spark is not saving it.  When I open it up again, the volume change beep will be unchecked.
I know its such a small issue, but I use the volume up/down change beep to get rid of the high pitched whine that sometimes occurs on my iMac (seems like playing a sound gets rid of it).
Is anyone else experiencing this?  Any solutions?  Thanks ahead.
« Last Edit: Sat, 27 November 2010, 16:36:46 by JLai »
Offline JLai
Spark Help
« Reply #1 on: Sat, 27 November 2010, 23:17:47 »
NVM...Went with keyremap instead.  Works like a charm.
