Author Topic: is there a list of decent compact keyboards? Smaller than filco tenkeyless?  (Read 4653 times)
Offline AvengeR
I don't want to spend $300 on a kb so a hhkb2 is not an option, and also read here it's not perfect but it'd be with realforce key feeling and build quality.
now I'm using a roccat arvo (I know, but I got it extremely cheap and it's rather small: 39,4x14cm, or 15.5x5.5 inches) but I think I would be even more comfortable with a smaller keyboard. Also I really dislike scissor switches so this keyboard does the work just fine because it feels better than regular rubber dome.
Of course "gaming optimized" key roll over is quite nice but not really necessary, as long it performs ok under ps/2 or usb. Also I don't care about fancy drivers, macros, etc.
i could potentially buy a filco but first those are expensive and second I want a smaller keyboard than that to really feel the difference in size. Filcos are 35.6x13.5cm, or 14x5.3 inches
The only other thing I'd really love to have is otaku/blank keys, but maybe I'm asking too much.
Thanks a lot
« Last Edit: Mon, 29 November 2010, 15:21:28 by AvengeR »
Offline theferenc
« Reply #1 on: Mon, 29 November 2010, 15:35:05 »
As far as I know, the list is:
1) HHKB Pro 2
2) HHKB Lite
3) GHSS
4) Siig Minitouch (upon which the GHSS is based)
I randomly saw a Ducky that was more compact than the Filcos, but I can't remember the number, and I can't find it anymore on PCHome. Add to that the difficulty of snagging a Ducky...you see my point.
Offline elbowglue
« Reply #2 on: Mon, 29 November 2010, 15:38:56 »
Consider my signature.
The main keyboard not listed is the Noopoo choco mini, avail for preorder in china.  The other alternative is the deck/tg3 82 key, which has cherry blacks..
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline msiegel
« Reply #3 on: Mon, 29 November 2010, 17:35:41 »
you can almost taste that chicklety goodness.
better go for it ripster :)
woody
  •  Guest
« Reply #4 on: Mon, 29 November 2010, 18:51:36 »
Cherry G84-4100.
Offline didjamatic
« Reply #5 on: Mon, 29 November 2010, 18:55:42 »
Ortek MCK-84
Frogpad (one handed scissor switch keyboard)
« Last Edit: Mon, 29 November 2010, 19:05:15 by didjamatic »
Offline kidchunks
« Reply #6 on: Mon, 29 November 2010, 21:55:26 »
Quote from: ripster;254049
You can take it and remap it to HHKB leetness in no time.
What app do you use to remap the keys?
Keep hitting the FN key on my ghss for ctrl..figure I set it that way since I hardly use FN.
Update:
Anyone have experience with sharpkey?
« Last Edit: Mon, 29 November 2010, 22:25:46 by kidchunks »
Topre || BS > *
my root : kidchunks[dot]com
Offline Azuremen
« Reply #7 on: Mon, 29 November 2010, 22:49:45 »
Quote from: ripster;254038
Somebody needs to explain to me the cultural significance of  the Chinese Characters in Noooooooooo Pooooooo sometime.
There's this for $18 at DealExtreme.  If somebody doesn't buy it soon I might have to actually break down and be the guinea pig.
I'm a bit curious now as well.
You should buy it.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
woody
  •  Guest
« Reply #8 on: Tue, 30 November 2010, 05:03:47 »
Quote from: didjamatic;254099
Ortek MCK-84
That's sweet. If they were still in production, I'd be getting some.
Offline victheslik
« Reply #9 on: Tue, 30 November 2010, 06:11:50 »
« Last Edit: Sun, 26 November 2023, 22:33:40 by victheslik »
"The only antidote to mental suffering is physical pain. " Karl Marx
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
