Author Topic: Stiff shift + control key on a filco  (Read 2964 times)
Offline sadbox
  • life coaching since 1990
    • sadbox dot org
« on: Thu, 02 December 2010, 22:06:30 »
My left control and shift keys have started acting kindof... stiff. They occasionally don't really click and don't really jump back up like the rest of the keys on the board. Is there something that I might have done (I can guarentee you that I didn't spill anything into it) or anything I can do to return those keys back to how they were?
This is on my filco tenkeyless w/ blue cherries
Work: Topre Realforce + CST L-Trac
Home: QFR (Blues, Blank Black PBT caps) + CST L-Trac-X
Offline sadbox
    • sadbox dot org
« Reply #1 on: Mon, 06 December 2010, 17:35:41 »
Well... I greased it and sadly it didn't actually solve my problem. At this point my shift key doesn't actually like to slide up all the way so that it will click... like after pressing it down it only pops up to right before it would reset the click. Needless to say it's pretty annoying when typing... I think I was just imagining the problem with the control key though!
Offline laden3
« Reply #2 on: Tue, 07 December 2010, 00:43:57 »
Quote from: ripster;256102
Follow the instructions here on how to remove and lube.
errr... how to remove the grease if you overdid it? well, it might be handy, especially for those who have plated mounted cherry style stabilizers.
« Last Edit: Tue, 07 December 2010, 00:46:26 by laden3 »
I rrrove brrracks.
Offline RickyJ
« Reply #3 on: Tue, 07 December 2010, 01:04:47 »
Maybe a plastic molding tag came loose and is jamming the switch mechanism?  Just throwing that out there.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline sadbox
    • sadbox dot org
« Reply #4 on: Tue, 07 December 2010, 01:37:20 »
When I tried it without the stabilizer numbs in it it was till doing it's weird hang-ey thing but without it was pretty obvious that it was hanging on the left side. Apparently it was rubbing against the left wall of the keyboard. Just a lil' visit from a nail file and I haven't had a single trouble since! My filco is saved!
