Author Topic: Used M2  (Read 2321 times)
Offline Laggy-gaga
Used M2
« on: Sat, 04 December 2010, 20:08:09 »
Part-No-1395300
link
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline 8_INCH_FLOPPY
Used M2
« Reply #1 on: Sat, 04 December 2010, 20:54:00 »
All of the IMB M2's I've used were particularly mushy rubber domes.  Is there any reason to think that this one is different?
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline Pylon
Used M2
« Reply #2 on: Sat, 04 December 2010, 21:00:10 »
1395300 are probably the buckling spring variant.
Offline Laggy-gaga
Used M2
« Reply #3 on: Sun, 05 December 2010, 02:09:10 »
cuz u got the 73G4614 ones which are rubber dome
go check IBM wiki which can help u to identify them
Looking for: 356L
AU only
Offline ch_123
Used M2
« Reply #4 on: Sun, 05 December 2010, 05:43:34 »
Of course, with M2s, you get the capacitor woes and the pretty dire construction quality.
Used M2
« Reply #5 on: Sun, 05 December 2010, 06:35:42 »
The seller says that it works, the model nr says that it is clicky.
If I lived in the US, I would bid on it.
It is loud though, and you don't want to open it up. (The plastic snaps break easily)
