Author Topic: This is why you remove the blood spatter guard from the TG3 BL82  (Read 2787 times)
Offline turbocharged
« on: Mon, 06 December 2010, 18:25:26 »
I got my BL82 in today and it's really neat...I love the back lighting on it, but damn does it take a lot of force to actuate a key. The rubber dome style "blood spatter" protector adds a tactile feel to the MX Black switches and a lot of force. Just to see how much force, I went to the nickel measurement system. I know it is not a perfect form of measurement, but for comparison sake it works.
I previously tested my Cherry MX-11900 with MX Black's and it took 13 nickels to actuate the switch and 17 to bottom it out (roughly 65g and 85g respectively). Well here is a picture of what it took to actuate and bottom out the TG3 with the blood spatter guard installed. (Note: Actuation and bottom out seems to be the same force because it doesn't actuate until the rubber dome gets over powered which is already above the force to bottom out a MX Black).
25 Nickels (125g) on what is probably a never used Pause/Break key and no actuation. I needed more nickels.
Finally...30 nickels (150g) and I get actuation. Now for a key that is probably well used.
The probably well used key (this was a used po-po board), the arrow key. It took 26 nickels (130g) to actuate. Needless to say...I will be removing the blood spatter guard later tonight with more pictures of everything torn apart.
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline Mr. Perfect
« Reply #1 on: Mon, 06 December 2010, 22:02:26 »
Blood spatter guard? Why in the world does it have a blood spatter guard? :twitch: Is it a medical keyboard that's really designed with a shield for medical waste, or are you just calling it that?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline RickyJ
« Reply #2 on: Mon, 06 December 2010, 22:07:09 »
Keyboards built for use in police cars.  May as well be a coffee spill guard.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline ricercar
  • mostly abides
« Reply #3 on: Mon, 06 December 2010, 22:26:30 »
My TG3 BL82 (newer vintage) has a thin saran wrap blood spatter guard. This adds nearly nothing to the force required to use the Cherry blacks.
My TG3 BLT (Trackpad) has a thick rubber blood spatter guard that required well more than 2x the force of a naked Cherry black. Your nickel numbers jive with my intuition/experience. Sounds like you have this kind of guard.
« Reply #4 on: Mon, 06 December 2010, 23:47:11 »
Quote from: ricercar;258441
Yes, I took it apart earlier..it is the thick rubber membrane style guard. Typing is smooth and easy now with the m'fin stock mx blacks.
[SIGPIC][/SIGPIC]
Offline chimera15
« Reply #5 on: Mon, 06 December 2010, 23:55:11 »
Quote from: Mr. Perfect;258423
No, donut crumb guard.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline ricercar
  • mostly abides
« Reply #6 on: Tue, 07 December 2010, 01:14:48 »
Quote from: turbocharged;258463
I'll take the spatter guard if you don't plan on keeping it.
« Reply #7 on: Tue, 07 December 2010, 09:13:43 »
Quote from: ricercar;258498
I probably want to keep it, but I will think about it.
[SIGPIC][/SIGPIC]
