Author Topic: Solidtek KB-6600BU  (Read 7674 times)
Offline kSKY
Solidtek KB-6600BU
« on: Fri, 10 December 2010, 21:17:32 »
i am on the hunt for my first mechanical keyboard and this caught my eye
http://ncix.com/products/index.php?sku=39598&vpn=KB-6600BU&manufacture=Solidtek
is it any good?
Offline godly_music
Solidtek KB-6600BU
« Reply #1 on: Fri, 10 December 2010, 23:05:22 »
Well it says on the manufacturer's page that the switches only last for ~10 million operations, that's 1/5th of a Cherry's lifetime. And they never say what switches exactly. It does say clicky.
http://www.solidtekusa.com/usb.htm#KB6600
Offline patrickgeekhack
Solidtek KB-6600BU
« Reply #2 on: Sat, 11 December 2010, 18:48:07 »
Simplified ALPS?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline AvroArrow
Solidtek KB-6600BU
« Reply #3 on: Sun, 12 December 2010, 03:05:17 »
kSKY, I assume you're in Canada since you're looking at NCIX.  I actually bought the KB-6600BU from NCIX maybe a year ago when it was cheaper (around $50ish).  It's also known as the ASK-6600U which you can find some info on if you search this forum.  I don't think it's worth $80.  It uses simplified/modified Alps switches, and "rings/tings" when you bottom out the keys due to the metal plate.  Yes, it's tactile, but you're better off with a blue Cherry board.  I also didn't like the backward L shaped Enter key, half-sized Backspace, and relocated Blackslash keys.  I got Filco tenkeyless NKRO blue cherry about half a year ago and have been very happy since.  Although I have to admit that the Filco cost almost 3x the price of the ASK-6600 after shipping and exchange (1.08CAD to 1.00USD) back when I bought it.
I think you'd be better off getting the Razer Blackwidow for $78.65 (SKU: 83044N) at NCIX if you're paying that price.  They also have another one listed for $84.99 (SKU: 57022).  Not sure why they have 2 differently priced listings for the same thing.  I vaguely recall it was because they came from different suppliers.  MemoryExpress.com also as the Razer for $84.99.  The reviews on the Blackwidow are sort of mixed since it's not a true NKRO board but instead uses some "gaming optimized" key matrix instead.  Another alternative is the Rosewill RK-9000 from newegg.ca for $99.99 + 12.24 S&H.  It's basically a clone of the Filco NKRO 104-key blue cherry board.  Unless you really need those 5 macro keys on the Blackwidow, I'd say the RK-9000 is probably your best bet unless you want a tenkeyless/87-key keyboard.
Offline twn2
Solidtek KB-6600BU
« Reply #4 on: Sun, 12 December 2010, 03:14:14 »
Quote from: AvroArrow;261618
Razer black widow is $70 at newegg.ca now.
Offline laden3
Solidtek KB-6600BU
« Reply #5 on: Sun, 12 December 2010, 04:51:14 »
try the marketplace too, some ppl might have something u like.
I rrrove brrracks.
Offline AvroArrow
Solidtek KB-6600BU
« Reply #6 on: Sun, 12 December 2010, 14:42:14 »
Quote from: twn2;261619
Was it a shell shocker or sale?  It's currently $79.99+$13.39 S&H (=$93.38+tax) at newegg.CA.  It's $70USD w/free shipping at newegg.COM.  It'd be cheaper to buy it locally from NCIX or MemEx if you have one local to you.  MemEx has free shipping for orders over $39 so if you don't live close to any of these stores then ordering it with shipping would be cheapest from MemEx.
If I had to go back to a 104-key keyboard though, I'd still get the RK-9000 over the others since I don't need macro keys.  I've read the build quality of the RK-9000 is the same as the Filcos, which is very good.  No broken internal frame parts like the Ducky from either crappy design or materials, which is why I haven't bought a Ducky even though I really like the alt-numpad mode and windows lockout keys of the 1087.
If OP wants something with brown cherries, then that only leaves the Das Silent boards... $125 at NCIX.  I think pchome or armygroup in Taiwan might still have some Filco browns in stock left in stock, but then after shipping & possibly customs charges +taxes, he'd be looking at $150+, probably closer to $170-180 depending on exchange rate.
Offline theferenc
Solidtek KB-6600BU
« Reply #7 on: Sun, 12 December 2010, 14:51:46 »
If you do look at the Das, and you're a student, make sure to ask about the EDU discount. It was 24% + free shipping, last time I looked at it. Though, that was in the US...not sure about the great white north.
Offline twn2
Solidtek KB-6600BU
« Reply #8 on: Sun, 12 December 2010, 15:24:47 »
Quote from: AvroArrow;261806
Ooops! I checked it two days ago, and it was $70 shipped. Now, it's no good to buy it in Canada.
