Author Topic: Filco numpad.. Is there a way to make num lock stay on?  (Read 3488 times)
Offline SpatiallyAware
« on: Fri, 10 December 2010, 21:40:15 »
Every time I reboot I have to remember to turn on num lock.  Is there a trick to making it stay on?
Maybe some small program that runs at start up and then shuts off?
Offline AndrewZorn
« Reply #1 on: Fri, 10 December 2010, 21:51:27 »
Option in BIOS for Numlock at boot.
EDIT though I just realized, do you mean this is a standalone numpad?  I don't know how that would go.
« Last Edit: Sat, 11 December 2010, 07:45:56 by AndrewZorn »
Offline nanu
    • http://T-T.be/portal
« Reply #2 on: Sat, 11 December 2010, 05:27:09 »
Quote from: SpatiallyAware;261114
An Autohotkey script could do this if you're too lazy to go into BIOS, yet don't mind the terrible thought of increasing your startup delay.
Code: [Select]
#NoTrayIcon
Send, {NumLock}
« Reply #3 on: Sat, 11 December 2010, 08:27:33 »
Being that it's USB I'm 99% sure there isn't a bios option for this
As a matter of fact, I don't believe I've seen num lock options in the bios for a long long time but I'll check..
Offline Hofy
  • Voids Warranties
« Reply #4 on: Sat, 11 December 2010, 12:39:57 »
While my stand alone USB numpad is not a Filco, (it is a Taiwan Twisty with Cherrys) my comes on every boot because of the BIOS setting.  This should only take you a minute to check.
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
« Reply #5 on: Sun, 12 December 2010, 05:13:00 »
Ok there is a num lock setting in bios and it has 0 effect.  Num lock is always off on reboot.  Bleh..
Thanks all!
