Author Topic: Xarmor Led Issues?  (Read 6027 times)
Offline Adhesive_X
Xarmor Led Issues?
« on: Wed, 15 December 2010, 20:57:54 »
Anybody having any issues with the LED brightness being uneven?
I had 3-4 letters with considerably weaker illumination. I exchanged for a different board and now have 2 numbers and a letter with the same issue.
Other than the lighting issue I like the board, but I know it will drive me nuts….
Any evenly lit boards out there? Wonder if I'm too picky?
Offline nmd
Xarmor Led Issues?
« Reply #1 on: Fri, 17 December 2010, 02:18:37 »
My Windows keys are a tad dimmer but I attribute that to the dome shape and the Windows symbol being lower positioned than the alphanumerical characters are on the remainder of the keyboard. Past that all the keys are evenly lit compared to each other.
There is a tiny bit of unevenness on keys like "Print Screen SysRq" where the top of the key is brighter than the bottom but that's because of the led positioninig under the cap. Same with backspace where the S is bright but it gets dimmer as you get to the B and the E away from the middle of the key.
Offline Phaedrus2129
Xarmor Led Issues?
« Reply #2 on: Fri, 17 December 2010, 02:38:12 »
Whenever you have 104 parts, some of them are not going to be exactly like the others. Electronic components have tolerances, and can be off by a bit. The more parts you have, the more chances for one or two to be off.
If  you really, really want an evenly backlit board you could get a backlit rubber dome with 6-12 LEDs. Or a real cheapy with just one sheet of chemiluminescent foil, though good luck keeping that glowing for more than a week.
Ooooorrr find out the specs of the LEDs and buy a dozen replacements to solder in. Or play RMA tag with XArmor, though that wouldn't be kind seeing as each board you return is a board they have to repackage and sell as open box later on, with no profit and the cost of shipping. They're not a high-volume company like Logitech or Razer.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Xarmor Led Issues?
« Reply #3 on: Fri, 17 December 2010, 12:45:07 »
It would be interesting to know whether this problem can be sorted out by resoldering the affected diodes (or corresponding series resistors or other components). If so, it would be plain ol' iOne soldering quality.
Offline ricercar
  • mostly abides
Xarmor Led Issues?
« Reply #4 on: Sat, 18 December 2010, 15:19:21 »
No noticeable LED variance on my U9BL.
Offline The Solutor
Xarmor Led Issues?
« Reply #5 on: Mon, 09 May 2011, 12:04:59 »
Quote from: ripster;264723
It's just LED brightness can vary.  For this reason I like to wire in parallel, not in serial.
[/URL]
Indeed leds on xarmor are wired in parallel.
Offline The Solutor
Xarmor Led Issues?
« Reply #6 on: Mon, 09 May 2011, 12:13:56 »
Quote from: Adhesive_X;263765
You are not too picky, but you have to keep in mind that led with stricter tolerances are costly, maybe even 50 /80 cents per led, when you need 106 of them this matters.
If you don't want to pay a backlit board like a topre you must accept that leds get dimmer with time and a small percentage of them get dimmer quicker than others
Offline The Solutor
Xarmor Led Issues?
« Reply #7 on: Mon, 09 May 2011, 12:16:45 »
Quote from: ripster;343879
I wonder why that one guy's "4" and "5" went out at the same time then.  I thought for a while the two were in parallel but 2.5V probably wouldn't be enough to drive the Blue LED.
Is enough for some kind of leds, deck use this wiring scheme: leds are in series in couple
Where did they GET these LEDs from?  Ebay?
Do you think they bought them from mouser at 1.75$ each ?
Offline BucklingSpring
Xarmor Led Issues?
« Reply #8 on: Mon, 09 May 2011, 13:14:04 »
All my U9BL-S leds are even and working.
Wait... Now none of my U9BL-S leds are working. :-(
Oups... Silly me, I forgot that the leds are turned off after reboots. I must turn them back on. They're working again. :-)
Boards I own, click ->
Offline ricercar
  • mostly abides
Xarmor Led Issues?
« Reply #9 on: Mon, 09 May 2011, 20:13:37 »
Maybe it's a soldering problem like in the M10s. Open the sucker up, reheat and stay in business.
Offline The Solutor
Xarmor Led Issues?
« Reply #10 on: Mon, 09 May 2011, 20:22:59 »
Quote from: ricercar;344096
Soldering are perfect on xarmor, as you can easily see looking at the shots I published when I bought the board.
Offline ricercar
  • mostly abides
Xarmor Led Issues?
« Reply #11 on: Mon, 09 May 2011, 23:17:17 »
Your board and mine are soldered well enough, have no failed LEDs. Perhaps the reason that OCN weenies are having problems with LEDs is that they have PCBs which are not soldered properly--like early M10s--and need some TLC like my Scorpius M10 did.
Offline The Solutor
Xarmor Led Issues?
« Reply #12 on: Tue, 10 May 2011, 01:14:01 »
Quote from: ricercar;344194
Hardly a bad soldered led become just dim, and if it happen light will be sensible to vibrations, it will blink, it will be sometimes lit sometimes not, but not dim.
And if for a coincidence this will happen, surely doesn't happen to two leds on the same board.
In that case the user is simply facing the normal tolerance of any consumer electronic component.
Just check any cherry board with ripometer, you will find that one or two switches are stiffer or softer, or less tactile than others.
When the absolute availability of a component is needed, industrial or military grade components are available, but at a price.
The fuel indicator of your car is less important than the one of a 747, indeed the former cost few dollars while the latter cost about 30000$
Offline The Solutor
Xarmor Led Issues?
« Reply #13 on: Tue, 10 May 2011, 01:25:15 »
Quote from: ripster;344259
Like the Scorpius M10 I recommend every Xarmor owner learn to solder.
Yes I'll not going buy Ford cars because the model T was so ugly...
Offline keyb_gr
  • Cherrified user
Xarmor Led Issues?
« Reply #14 on: Tue, 10 May 2011, 07:38:50 »
That's how it came from the factory? Looks like this part was reworked by hand, by someone whose soldering isn't too much more impressive than mine. (And I usually don't see very well what I'm doing.)
Offline craZivn
Xarmor Led Issues?
« Reply #15 on: Tue, 10 May 2011, 10:11:51 »
To the OP: Pop the keycaps off of the dim keys and make sure the LEDs are seated properly and pointing up straight (pull the cap off one of the bright keys for comparison). If an LED is angled a bit it can appear dimmer. Just a thought.
CZI
Offline The Solutor
Xarmor Led Issues?
« Reply #16 on: Tue, 10 May 2011, 10:29:13 »
Quote from: keyb_gr;344322
Not reworked, just finished by hand (or by a different hand).
Clearly the worker that made those soldering was likely on its second day of training
