Author Topic: How to reduce activation force with White Alps? (Fukkas)  (Read 2950 times)
Offline froogle
« on: Thu, 16 December 2010, 12:24:19 »
I currently use the Sigma AFK-7100MC. I find that the key presses are lighter than my previous old rubber dome keyboard and so it is more comfortable than that. However, I have had a try on the Apple Aluminium Chiclet keyboard and the standard OEM HP low profile keyboard and found that I enjoyed typing on them more.
This was directly down to the activation force...I liked the lighter keys...
So, here is my question; how should I go about reducing the activation weight of the White Alps Fukka switches? I heard that one can cut the springs to shorten it, therefore making it lighter but I fail to see how I would achieve this evenly on every switch.
Thanks in advance guys.
from, the guy who is about to leave his first ever mechanical keyboard for an Apple Aluminium one...
Offline Pylon
« Reply #1 on: Thu, 16 December 2010, 14:15:44 »
If you don't mind a linear key feel, you can remove the tactile/clicky leaf in the switch, which will give you a substantially lighter, but linear feel.
Offline 8_INCH_FLOPPY
« Reply #2 on: Thu, 23 December 2010, 01:34:02 »
Don't mess with ALPs man. They will Fukka you up.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline javifast
Too many keyboards....
