Author Topic: Help! (or: how to open a SGI granite mouse)  (Read 3915 times)
Offline 7bit
  • MX1A-G1DW
« on: Fri, 17 December 2010, 15:11:50 »
I need some help:
No screw on top, but you and me expected this.
But, ...
... no screw here, either!
You might suggest to push that ball-cover towards arrow-direction, but nope.
Seems to be glued!
Now help me, please! What should I do?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline msiegel
« Reply #1 on: Fri, 17 December 2010, 15:14:57 »
is it under the part number label?
Offline msiegel
« Reply #2 on: Fri, 17 December 2010, 15:17:37 »
http://forums.nekochan.net/viewtopic.php?f=3&t=16718611
edit: that's the only view of the inside i could find :-/
« Last Edit: Fri, 17 December 2010, 15:24:32 by msiegel »
Offline 7bit
  • MX1A-G1DW
« Reply #3 on: Fri, 17 December 2010, 15:24:50 »
Quote from: msiegel;264809
Yes, it is. I feel the screws. But I can't open that ball cover, seems it is glued mayby because it fell off once in a while.
Quote from: msiegel;264811
I know that mod, thanks for the link!
So I will have to clean it the hard way :-/
edit: OK, got the ball-cover loose without breaking anything.
uffffffffffff.
« Last Edit: Fri, 17 December 2010, 15:34:12 by 7bit »
Offline D-EJ915
« Reply #4 on: Fri, 17 December 2010, 21:15:16 »
I tossed mine in the trash because it was such a piece of crap but i did have the beige version
