Author Topic: spacebar easily depressed ?  (Read 1920 times)
Offline Moogle Stiltzkin
« on: Sat, 18 December 2010, 05:07:40 »
Quote from: xcen,Dec 18 2010, 02:34 PM
Yeah, blank keycaps, free palm rest but no mousepad. :(
Total is MYR438 and a few cents.
The Black switch spacebar really needs some serious getting used to lol.
Still getting used to the lightness of the switch compared to rubber dome keyboard. Getting double spaces quite often.
Is this normal ? Any ideas :/ ?
This is for a ducky 9008 model. Could this be related to a loose spacebar. I think someone before had to resolder the spacebar.
« Last Edit: Sat, 18 December 2010, 05:20:28 by Moogle Stiltzkin »
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline godly_music
« Reply #1 on: Sat, 18 December 2010, 05:21:54 »
When you are the widest kid on the playground, you are easily depressed.
Offline sixty
    • http://deskthority.net
« Reply #2 on: Sat, 18 December 2010, 05:25:48 »
lol
topic: it should be the opposite, the black spacebar should use a grey switch, which needs nearly 80g
« Reply #3 on: Sat, 18 December 2010, 05:32:16 »
How do you go about converting from a black to a grey switch ?
By just changing the spring ?
Lowyat15
15 USD discount.
Offline sixty
« Reply #4 on: Sat, 18 December 2010, 05:43:55 »
Yes. If it is a grey switch in the Ducky too he should just solder out something like scroll lock and swap it for the spacebar.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #5 on: Sat, 18 December 2010, 08:29:49 »
What do they use on the spacebar anyway? My understanding was that the Duckys with browns had a black switch there (unless I'm mixing things up). I doubt we have a grey one here, at least I can't imagine anyone complaining about it being too light.
While linear MX switches are the most likely to exhibit accidental double presses, there shouldn't be that much key bounce. This may indicate either a soldering problem (as mentioned) or a "bouncy" switch contact that possibly could use a bit of bending or just replacement.
« Reply #6 on: Sat, 18 December 2010, 08:32:49 »
@keyb_gr
I'll ask them again what keyboard they got exactly. But all i know is he says his spacebar is a black switch.
But if this is not normal, he probably needs to send it for warranty :/ cauz i don't think he would know how to change the switch or do the soldering.
Anyway Dk-9008 cherry mx browns come with brown switches for the spacebar.
It was observed in a DK-9008 cherry mx blue (by squarebox) that his switch was black.
There is going to be a special edition of new DK keyboards that have cherry mx brown; with cherry mx clears for the function keys. But what you get for spacebar i don't know.
*update
He is using a Ducky Dk-9008 cherry mx blue switches; but has a black cherry mx switch for the spacebar.
« Last Edit: Sat, 18 December 2010, 08:38:11 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline xcen
« Reply #7 on: Sat, 18 December 2010, 10:35:20 »
Hmm? I don't think there's anything wrong with my keyboard. I think it's just my habit that needs changing.
The spacebar doesn't double tap if I intentionally just go press the key once.
