Author Topic: Cherry Product code  (Read 3094 times)
Offline FrittenFett
Cherry Product code
« on: Mon, 20 December 2010, 06:48:50 »
http://cgi.ebay.de/Cherry-Testatur-MultiBoard-G81-7000-BLACK-Magnetkarten-/220630091361?pt=M%C3%A4use_Tastaturen&hash=item335e940661 - Anyone knows what language is the TS in the product code?
The only thing i found was Tsonga and that would be really creepy. :crutch:
Offline 7bit
  • MX1A-G1DW
Cherry Product code
« Reply #1 on: Mon, 20 December 2010, 06:53:23 »
Quote from: FrittenFett;266088
It has a special Czech/US layout. Look at those Z/Y keys. If you want the caps, go for it. They look double shot.
Fotget the board itself, G80 are those what we are all after. G81 have compatible caps, though.
edit: G81-7000LUATS-2/00
The L means lasered, so they are lying with their pic!!!
The first letter of 3 or 5 letter codes must be H.
=> skip it!
« Last Edit: Mon, 20 December 2010, 07:00:39 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline sixty
    • http://deskthority.net
Cherry Product code
« Reply #2 on: Mon, 20 December 2010, 07:02:27 »
Keys look lasered on the pics too actually.. wouldnt say they are lying. Lasered black keys are not too bad, they are thick and usually made of POM. I think this may be a SWISS layout. Those have both Z and Y too..
Anyway, if you plan to use the keycaps on a G80, they will most likely all fit but with a chance of Enter, Space, Shifts, Numpad + and Numpad Enter not fitting at all. This depends on the generation on the keyboard and is impossible to tell unless you get one.
Offline FrittenFett
Cherry Product code
« Reply #3 on: Mon, 20 December 2010, 07:03:34 »
Well, I know. I already have a G80 3000. :D
So you would say they created a product code themself?
hm....
Offline 7bit
  • MX1A-G1DW
Cherry Product code
« Reply #4 on: Mon, 20 December 2010, 07:09:01 »
Quote from: sixty;266092
Kuckst Du hier:
Czech_2
Sorry, CNR.
Offline theferenc
Cherry Product code
« Reply #5 on: Mon, 20 December 2010, 13:16:33 »
At least in the US, you REALLY have to check with the seller about the product code. I bought a G80 that I thought was a 89xxLUBUS-2, got a 8113HUBUS-2 in its place.
In other words, don't necessarily trust the description or the pictures, as quite often, they get it wrong.
Though, in my case, I was quite happy with my new POS board with double shots...
Offline FrittenFett
Cherry Product code
« Reply #6 on: Mon, 20 December 2010, 14:52:10 »
Well, that's always the better ending. Mostly you get the worse one. :frown:
