Author Topic: Bunch of Model M keyboards, going to go cheap  (Read 4416 times)
Offline MissileMike
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline wanabe
« Reply #1 on: Mon, 20 December 2010, 09:41:53 »
this will be interesting to see... i wonder if geekhackers make up enough of the market for M's to effect the final price.
Offline Sam
« Reply #2 on: Mon, 20 December 2010, 10:15:49 »
What if they're all 71G4644s (rubber domes)?  Somebody(s) will be mighty pissed.
Offline Sam
« Reply #3 on: Mon, 20 December 2010, 10:21:36 »
Quote from: MissileMike;266124
They appear to be 52g or similar models, and from the pic, look in great condition.
Uhm, actually that should be "it", not "they", being there's only one pic of one keyboard that was duplicated.  For that matter, it might not even be a pic of any of the actual keyboards being sold.  Notice one of the listings says "This keyboard is missing the right shift key completely and the backslash-pipe keycap.", but the picture obviously doesn't match this description.  Also the words in all the listings, "could probably use a good cleaning" doesn't seem to match the picture off-hand.
Seller has only 58 positive feedbacks.  I'm not totally convinced myself that this will turn out to be a good deal.  But if it's cheap enough, might be worth taking the risk.
Offline jnsjr
« Reply #4 on: Mon, 20 December 2010, 10:24:57 »
Giving it a shot, I'm the high bidder on the 4th link. Thanks Mike!
Current Keyboards
Unicomp Space Saver (white) ~ HHKB2 ~ White Filco Red Cherry Limited Edition (Imsto Grey on White PBT + Group 3 keys + Awry keys)  ~ Realforce 87U 45g + Realforce 87U Variable + Realforce Numpad :biggrin1:+ MJ2 White Blue Cherry 87key
Keycaps
ClickClack Red Eye Skull *(2)* *(3)* *(4)*~ Black Eye Skull *(2)* *(3)* ~ Closeup ~  Topre WASD (Thanks Yak & DB!)
WTT & WTS
WTS White Filco Red Cherry Limited Edition (still deciding!)
Sold ~ Filco Blue Cherry; Majestouch 104 nonprinted keycaps; Noppoo Choco Mini 茶轴 (brown switches);  Topre 87u Variable ; Topre 87u 55g ; MY7000 Doubleshots ; Round 1 Doubleshots
[/FONT]
[SIGPIC][/SIGPIC]
Offline MissileMike
« Reply #5 on: Mon, 20 December 2010, 10:39:15 »
Wait til the end to bid man!  Use EZSniper or something :)
Offline theferenc
« Reply #6 on: Mon, 20 December 2010, 13:20:17 »
You people who use technology to futz with auctions really infuriate me. Sorry, but it's just so blasted dishonest.
Sorry, I'm a little bitter about a few lost auctions that were clearly won in this fashion.
No offense, Mike, it just really rubs me the wrong way. More power to you, though.
Offline MissileMike
« Reply #7 on: Mon, 20 December 2010, 14:01:47 »
Quote from: theferenc;266290
I would do the same exact thing manually if EZSniper didn't exist. Personally, I see absolutely no point in bidding until the final 10 seconds.
Offline wanabe
« Reply #8 on: Mon, 20 December 2010, 14:38:24 »
I agree, ebay is an open market.  i do the same thing manually
Offline elef
« Reply #9 on: Mon, 20 December 2010, 17:24:07 »
Quote from: seller
I'm only getting rid of it because I can't actually use it any more and I'm quite sad to see it go.
When this is posted by the same guy in 6 different auctions at the same time and they all have the same photo, well, that doesn't inspire a lot of confidence in the honesty of the seller. Was he using all 6 until he got rid of whatever computer he used to have???
Offline Sam
« Reply #10 on: Mon, 20 December 2010, 17:35:43 »
I don't use any tools myself, but don't have a problem if someone does.  As mentioned, it shouldn't really be any different than if they manually put in the same bid at the last second.  Being the auction ends at a specified time, last second snipers tend to restrict the amount of emotional bidding that goes on in bidding wars.  Sometimes bidders get caught up in it and bid more than they really wanted to, simply due to their emotional reactions.  I try to leave my emotions out of it and simply but in my maximum bid, and if someone else wants it more than me, well that's what a free market is all about.  No bad feelings there.
Offline porkbone
« Reply #11 on: Mon, 20 December 2010, 18:29:08 »
Quote from: ripster;266299
Sniping is the only logical way to do Ebay.
Agreed.  Auctionstealer FTW.
Um.... HEY!
In a related story, since it was foretold here that I needed to buy a Model M now, what would be a good one to look for?  This little thread for example taught me that whatever a 71G4644s is, if I got one I'd be pissed.
Offline Sam
« Reply #12 on: Mon, 20 December 2010, 18:38:27 »
For the most part, Model M's all use buckling spring technology - mechanical clicky switches.  The one exception (that I know of) to this is the Model M 71G4644, which uses those awful feeling rubber dome switches.  See here for a picture and description of it from ClickyKeyboards:
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/9608/subcatid/0/id/464118
As you can see, it looks just like the other Model M's of that era, but if you buy it thinking it's a clicky, you're in for a big surprise.
So blindly buying a Model M of this type without knowing the model number is a bit of a crap shoot as there's plenty of these things out there.
Offline MissileMike
« Reply #13 on: Mon, 20 December 2010, 18:49:28 »
Yes these are a total crapshoot, but a cheap risk at least.
Offline wanabe
« Reply #14 on: Mon, 20 December 2010, 18:50:20 »
porkboner just read this... http://www.clickeykeyboards.com/model-m-buyers-guide/
it's pretty much everything that you'll need to know.
Offline Sam
« Reply #15 on: Mon, 20 December 2010, 19:20:51 »
Quote from: wanabe;266458
That's a good guide.  One mistake though that I think is worthwhile noting.  The guide mentions the 101-key terminal boards which don't work directly with PCs.  All of these that I've seen are 102-key boards, not 101-key boards.  The legends on the key caps are normally different from those designed for PCs, but sometimes the legends aren't clear.  So I found the way to immediately spot a terminal vs. PC keyboard is to look on the right-most column of keys over on the keypad.  Terminal boards have four keys there, three regular sized, and one double size.  PC boards have only three keys in that column, one regular and two double size.
I cannot guarantee that this works for every single 101/102-key Model M, but it's held true for all that I've checked.  For any other IBM keyboards though, this may not hold true.  For example, the Model F PC AT board has four keys on the right, but is PC compatible.  Ultimately it's best to check what the connector looks like, but if that's not possible, I think my quick check will steer you correctly in almost all cases.  Someone please post if you know any exceptions to this 101 vs 102 key rule.
Offline Sam
« Reply #16 on: Mon, 20 December 2010, 20:13:55 »
All sniped by the same person except for one.  I suppose with combined shipping it was a pretty good deal as long as they were clickys, being they went for the $11 - $22 range.
Offline Moogle Stiltzkin
« Reply #17 on: Tue, 21 December 2010, 15:36:39 »
Quote from: Sam;266475
I'll bet it ends up back on ebay double the price. But i guess that iss free market for you, but still; if i do buy something, i actually do bother to use it :smow:
"So long as we do not depend on the facts entirely, incomplete knowledge is better than complete ignorance."
:bounce:
Current gaming keyboard: Ducky DK-9008 with Cherry Beige/White doubleshots (Cherry Mx Brown)
For my 2nd pc: Cherry G80-1095 HAU Revision 00 (Cherry Mx Black)
Dye subbed keys harvested from NCR 3299-k440-v001 G80-3007 SAU. Casing donated to Mike.
[/FONT]
Free mechanical keyboard + other gear click here![/color]
