Author Topic: Double shot replacements ROUND THREE: Vote for Kits & Quantities!  (Read 1185462 times)
Offline tacite
« Reply #2150 on: Tue, 22 March 2011, 09:05:12 »
Quote from: speakeasy;315863
Yikes! I owe more than expected since CHERNOBYL costs more than I thought it would :(
Hey 7bit, it says there are 15 orders for CHERNOBYL at $8 a pop. The thread said it would be $3 at 25 orders. Would it be possible to just double all our orders to bring it past the 25 key threshold and giving us a $2 refund, seems like a win-win cause we get an extra key AND save $2. The same might be true for other keys too.
Chernobyl is now for $5, if 15 are produced.
FILCO Majestouch Tenkeyless
(FKBN87MC)
[sigpic][/sigpic]
Offline 7bit
  • MX1A-G1DW
« Reply #2151 on: Tue, 22 March 2011, 09:05:45 »
Quote from: Twitchy;315859
I hope that this SVG for pirate flag is good. Should look like:
Edit: Will they centre it themselves or do I need to ensure that the width of the SVG matches the keytop and centre the image myself?
 I will tell them that any SVG should be as large as possible on a key and centered, so it is OK except that I just see that the SVG graphic exceeds the boundary at the bottom!
PS: Looks like the head of the girl who waited for her lover until he had found that last bug ...
« Last Edit: Tue, 22 March 2011, 09:08:47 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Twitchy
« Reply #2152 on: Tue, 22 March 2011, 09:18:05 »
Oh FFS! I see that your image is clipped at the bottom (and a little on the right). It's clipped when I open it in Opera, but not in Firefox or Inkscape. WTF? I'll play with it some more and see what I can do.
Stuff
Filco Majestouch FKBN88M/UKB2
Topre Realforce 91UBY
Razer Imperator + Razer Vespula[/COLOR]
Offline Twitchy
« Reply #2153 on: Tue, 22 March 2011, 11:22:16 »
After many iterations and much searching on the web (didn't find anything to help there!), I think that this should work.
The first SVG I uploaded was set at 10.84mm high with no border. Adding some empty space around the edge stopped the appearance of cropping in Opera but I figured that the border might result in a smaller keycap legend (assuming that SP scale the entire document to the keycap and not just the picture within). But in a moment of inspiration I decided I'd try to save the SVG on a much larger scale (500mm high) with no border and it now looks fine in Opera (the only external means of testing that I have) so I'm hoping that SP will scale it down to fit and we'll be fine. If not I'll be looking for my suicide pill!
I know that it's not really a fix as the SVG still looks slightly clipped at the bottom (I hope that it doesn't worsen when SP scale it down) but I'm all out of ideas.
« Last Edit: Tue, 22 March 2011, 11:27:43 by Twitchy »
Stuff
Offline Fwiffo
« Reply #2154 on: Tue, 22 March 2011, 11:26:38 »
I generally use Inkscape to render bitmap versions of SVG files because every other implementation I've seen is broken or out of date.
You can call me... Keyboard Otaku... or not quite...
Offline Twitchy
« Reply #2155 on: Tue, 22 March 2011, 11:30:24 »
What, just exporting as BMP or is there something elsewhere that I've missed?
Stuff
Offline bontosaurus
« Reply #2156 on: Tue, 22 March 2011, 11:49:31 »
DCS - 1X ROW 1 - ORANGE (OAZ)
DCS - 1X ROW 2 - ORANGE (OAX)
Can someone please explain these to me?  I'm trying to order a full set of orange blanks.  I got an email saying ...
Your current votes are:
ORANGEBLANKFULL 1
Does this mean I have already "ordered" as well?
Offline Fwiffo
« Reply #2157 on: Tue, 22 March 2011, 11:54:33 »
Well, not BMP. Screw that format, they put the bytes in backwards. But I'm not sure what you're asking...
Offline 7bit
  • MX1A-G1DW
« Reply #2158 on: Tue, 22 March 2011, 12:27:37 »
Quote from: ripster;315998
When is the first batch of keys going to ship to iMav?  I was hoping for Lady Gaga but will take Leonardo.
Nice calendar.
There will be only one batch this year.
Production takes 5 weeks. If we are lucky, the 40ft container will arrive in the first week of May 2011. iMav has then got one month to do the collation and shipping, because in June a longer train fully loaded with keyboards will arrive at his packaging and shipping facility.
« Last Edit: Tue, 22 March 2011, 12:31:49 by 7bit »
Offline Twitchy
« Reply #2159 on: Tue, 22 March 2011, 12:29:57 »
Quote from: Fwiffo;315991
Never mind, neither am I :s
From what you'd said I thought you might have some insight is all. I've been bumbling around in Inkscape trying to feel my way. I've little interest in doing tutorials at this stage when all I want is to create a little file for a keycap. There's probably something fundamental about SVGs that's causing the apparent cropping and I've yet to find it.
Stuff
Offline 7bit
  • MX1A-G1DW
« Reply #2160 on: Tue, 22 March 2011, 12:34:29 »
Quote from: ripster;316014
So Summer 2011 then?
Is it OK with you if I just contact Signature Plastics directly about the Awesome/Reddit keys?
You can contact them directly, or just tell me what you want.
Offline Fwiffo
« Reply #2161 on: Tue, 22 March 2011, 12:42:33 »
Well, I'm able to open your original svg file in Inkscape and it looks OK, and I am able to export it to a .png file that looks OK. Looking at the SVG markup, there is a weird, unnecessary transform element in there, so I resaved it here in a more minimal format at the correct dimensions. Can you check out that version and see if it works better for you?
Offline 7bit
  • MX1A-G1DW
« Reply #2162 on: Tue, 22 March 2011, 13:35:30 »
Quote from: ripster;316020
Well, I was hoping to have my kid sell them this Summer and really would like to see a sample of the Awesome/Reddit key in real life before then.
The only thing I could do about that, is to ask if they can produce the Awesome and Reddit faces before everything else and ship your load separately straight to you.
Offline 7bit
  • MX1A-G1DW
« Reply #2163 on: Tue, 22 March 2011, 13:41:46 »
Quote from: Fwiffo;316026
OK, I fine-tuned the width and height manually (as always in emacs).
Now it is OK, except if you don't like the design.
Offline muchadoaboutnothing
« Reply #2164 on: Tue, 22 March 2011, 14:24:06 »
Only a few hours left. I have to see if I will make changes on my vote or if my alligator arms will save my wallet.
Offline guilleguillaume
« Reply #2165 on: Tue, 22 March 2011, 14:37:50 »
I had no response about the kits that should be erased on my vote.
I actually think that with the holydays break 7bit had some things are confusing to me. I'm still receiving my votes without the main updates I did last days. I do not want to have 2 boxes shipped so I can't afford having that many sets on my order since they will not fit on one box.
I voted CLEARBLANKFUN and CLEARBLANKMOD to replace POS since this last kit have 48 pieces and the other two have both in total similar amount of keys.
7bit can you confirm that this will fit in one unique box please?
AWESOMEYELLOW 3
AWITHDOT 2
CLEARBLANKFUN 1
CLEARBLANKMOD 1
JAPANESEFLAG 1
KEYBOARDLOVER 2
ONEHALFMOD 1
ORANGE 1
SHIPWW 1
SPACEGREY 1
SPACEORANGE 1
STANDARD 1
WHITEONBLUE 1
Actually having 2 boxes sent for me is a no way since I don't trust that all will arrive without poblems taking as an example my own experiences with this kind of shipments.
Thanks
« Last Edit: Tue, 22 March 2011, 14:42:13 by guilleguillaume »
Offline krazymunky
« Reply #2166 on: Tue, 22 March 2011, 15:15:55 »
new to this. i sent my vote to 7bit_vote. does that mean ive preordered? or did i miss the 'add on' date?
edit// lol i just got my invoice...5 mins after i added something my order :( and my new item isnt there
« Last Edit: Tue, 22 March 2011, 15:21:35 by krazymunky »
Offline 7bit
  • MX1A-G1DW
« Reply #2167 on: Tue, 22 March 2011, 15:26:30 »
Quote from: krazymunky;316137
Everything is OK!
I will send the new updated invoices very soon!
BTW: @all
Please send 7bit_vote a message with the following line:
EMAIL your email address
Those who do not give me their e-mail addresses, will recieve their invoices somwhere tomorrow, or even later, becuase I can't send 40 messages manually. It takes me 1 minute per message, it's insane!
Offline Koeitje
« Reply #2168 on: Tue, 22 March 2011, 15:26:36 »
Bleh, AWESOMEORANGE (thats awesome face in white on orange key) is so expensive. Please, more people order this! Will fit nicely with the gamer orange kit, better than the black on orange.
Offline HungryPillow
« Reply #2169 on: Tue, 22 March 2011, 15:28:58 »
I'm slightly confused here, there have been so many invoice versions sent out I don't know which one to rely on.
I added blue blanks to my order a while ago, and I got a corresponding invoice with blue blanks on it. On that invoice it says I have $2.00 in my account.
I just received another invoice and there are no blue blanks on it. On this invoice it says I have $21.00 in my account.
Does this mean the blue blanks aren't happening? How do we go about getting a refund for the remaining amount?
Realforce 87U | Realforce 104U | Filco Majestouch MX Blues | Corsair K70 RGB MX Browns | Ducky Shine 4 MX Clears / Browns | WhiteFox Aria MX Browns
Offline 7bit
  • MX1A-G1DW
« Reply #2170 on: Tue, 22 March 2011, 15:37:16 »
Quote from: HungryPillow;316146
More and more people jumped off the blue blanks.
These invoices contain only those kits which will surely make it and for which I'm quite confident they will be ordfered in at least these quantities.
For the rest, please wait until tomorrow.
« Reply #2171 on: Tue, 22 March 2011, 15:40:02 »
Quote from: 7bit;316150
Ah ok, got it. Thanks.
Offline DaemonRaccoon
« Reply #2172 on: Tue, 22 March 2011, 15:45:14 »
What can I get for $2.25? Everything keeps getting cheaper. (And here I was, thinking I'd have to send more money to iMav...)
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline 7bit
  • MX1A-G1DW
« Reply #2173 on: Tue, 22 March 2011, 15:49:21 »
Quote from: DaemonRaccoon;316165
Get another space bar. They get shiny really soon!
Offline 7bit
  • MX1A-G1DW
« Reply #2174 on: Tue, 22 March 2011, 15:50:39 »
Quote from: ripster;316171
$2.25 can get you a Big Mac on Thursdays.
Are these double shots?
Offline Megaweapon
« Reply #2175 on: Tue, 22 March 2011, 15:51:03 »
COMMODORE is in!  Thanks to everyone who ordered!
With that out of the way, I am now officially in the camp of the people who want to wrap this order up fast (before anyone changes their mind).
Ancer Research Groop DFK191ABA11 IBM Model M13 Part 92G7461 (white) Rosewill RK-9000
Matias Tactile Pro 3 Apple Extended Keyboard II (ALPS)
Rosewill RK-9000I
Offline Ekaros
« Reply #2176 on: Tue, 22 March 2011, 15:51:20 »
Geekhack seem to have poor userbase in Mexico...
Sad have some room(178), but nothing more I might want or no premade blanks, or isthere?
Updated my shipping address, should be that for month or two atleast.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
« Reply #2177 on: Tue, 22 March 2011, 16:08:26 »
Quote from: 7bit;316170
I took your advice. Now iMav can't go to McDonald's... :rain:
Offline wuzle
« Reply #2178 on: Tue, 22 March 2011, 16:12:30 »
7bit, looks like the GNOME key is listed twice, i got double billed for it in my invoice.
Offline shoto1699
« Reply #2179 on: Tue, 22 March 2011, 16:17:08 »
im confused about my invoice. where is my total?
is it this?
Total including shipping: $10.00
Offline 7bit
  • MX1A-G1DW
« Reply #2180 on: Tue, 22 March 2011, 16:17:22 »
Quote from: wuzle;316192
Thanks for finding this bug!
Offline Culinia
« Reply #2181 on: Tue, 22 March 2011, 16:20:40 »
Quote from: shoto1699;316198
is it this?
Yes but that means that you can buy $10 more keys not the total value that you have paid. If that's what you mean?
Offline 7bit
  • MX1A-G1DW
« Reply #2182 on: Tue, 22 March 2011, 16:22:40 »
Quote from: Culinia;316204
No, this is what he has to pay.
Otherwiese it would say:
You have got $10.00 in your account.
« Reply #2183 on: Tue, 22 March 2011, 16:22:50 »
Nice! I have got my invoice. :)
Hmm.. I seem to have voted for "SHIPWW" and got the cost of shipping included in the "Total before shipping".
Should I reset that (vote "SHIPWW 0") and wait for a new invoice, or should I reply to the email?
Offline manfaux
« Reply #2184 on: Tue, 22 March 2011, 16:24:47 »
Old Question, will the invoice be updated on how much I still owe imav? because I've paied once earlier and then added some more later on.
thanks!
Offline Culinia
« Reply #2185 on: Tue, 22 March 2011, 16:25:14 »
Quote from: 7bit;316206
My bad.
*hides back in corner* LOL
Offline 7bit
  • MX1A-G1DW
« Reply #2186 on: Tue, 22 March 2011, 16:28:42 »
Quote from: Findecanor;316207
I know!
My script looks if there is a shipping address, not if there is something like SHIPWW included.
Just reply to the invoice with your shipping address preceded.
@all: use 7bit ASCII, if possible!
Offline tacite
« Reply #2187 on: Tue, 22 March 2011, 16:34:56 »
7bit: about pirateflag, pls can you specify color of  this key? White on NN or GX? (i prefer GX but it's up to you)
(FKBN87MC)
[sigpic][/sigpic]
Offline jdreamer
« Reply #2188 on: Tue, 22 March 2011, 16:44:34 »
I just received my new invoice but I made some changes and they didn't show in the new invoice. Should I send another PM to 7bit_vote or I'll just wait?
My life for Aiur!
Offline 7bit
  • MX1A-G1DW
« Reply #2189 on: Tue, 22 March 2011, 17:34:56 »
Quote from: tacite;316220
I think it should be GX to fit into the main color scheme.
Offline shoto1699
« Reply #2190 on: Tue, 22 March 2011, 17:46:18 »
well i paid for my stuff :D
Offline phuzion
« Reply #2191 on: Tue, 22 March 2011, 17:52:20 »
Just curious, should I be paying for these as goods, or as a gift?
Keyboards Owned: Cherry G80-1800 - 3x Filco Majestouch-2 Tenkeyless NKR ASCII, Reds, Browns, and Blues - Dell L100
Offline wap32
« Reply #2192 on: Tue, 22 March 2011, 17:53:17 »
Payment has been sent...again. =)
Offline suntorytime
« Reply #2193 on: Tue, 22 March 2011, 17:54:13 »
Quote from: phuzion;316275
Gift so someone doesn't get short dimed on Paypal fees.
Offline 7bit
  • MX1A-G1DW
« Reply #2194 on: Tue, 22 March 2011, 17:54:30 »
as GIFT!
[SIZE=8]Vorsicht Gift![/SIZE]
« Last Edit: Tue, 22 March 2011, 17:58:20 by 7bit »
Offline narlzac85
« Reply #2195 on: Tue, 22 March 2011, 17:57:17 »
Call me a noob, but I've haven't used paypal in so long that I didn't know I had to transfer funds into it. So, gonna be 2 or 3 days before I can make the payment. Don't cancel my order 7bit!
Offline 7bit
  • MX1A-G1DW
« Reply #2196 on: Tue, 22 March 2011, 17:58:54 »
Quote from: narlzac85;316287
No problem!
Offline wap32
« Reply #2197 on: Tue, 22 March 2011, 18:00:56 »
Quote from: 7bit;316281
as GIFT!
Oh man, I didn't know this!
I'm not used to sending money through paypal except when using ebay.
Just tell me how much are taxes (or how to calc them) and I'll send that value to iMav as a gift.
Offline Ekaros
« Reply #2198 on: Tue, 22 March 2011, 18:02:12 »
Quote from: suntorytime;316280
Yep, those guys are expensive...
[SIGPIC][/SIGPIC]
Offline 7bit
  • MX1A-G1DW
« Reply #2199 on: Tue, 22 March 2011, 18:14:47 »
Quote from: Ekaros;316296
On the other hand, prices might sink down a bit until tomorrow and all of you have suddelnly again some $$$ in your account and can get even more key caps which again reduces the prices ...
