Author Topic: Weird roll over problem.  (Read 1325 times)
Offline sam113101
« on: Wed, 22 December 2010, 23:21:42 »
If I press my two shifts and the w key, it works. If I press my two shifts and the q key, it does NOT work. It happens with few random keys. I sniffed with wireshark to figure out I still receive a ErrorRollOver.
Okay, my board isn't NKRO, it's a unicomp spacesaver. But I should be able to do it too, no*? It's two modifiers and only one normal key. I don't get it. It's the same with other keyboards too, though not with the same keys. Depends of the matrix I'd say.
Hoping to hear from you again, your dearest friend, sam113101.
Offline Ekaros
« Reply #1 on: Thu, 23 December 2010, 00:35:57 »
Quote from: ripster;267614
Yep, it's all the matrix.
Gaming optimized keyboards look like the Tokyo Subway system. A G15.
I recommend you don't type with both shift keys held down.  It's very inefficient.
Yep, only reason to do it as I see is for some old school co-op pc-games... Or is there others? Still show just how cheap keyboards are...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
