Author Topic: Spacebars, ease of pressing at any point  (Read 2671 times)
Offline killy
« on: Tue, 28 December 2010, 11:51:21 »
I had one of those fat, creamy white vintage keytronics for a while and despite it being rubber dome I liked it quite a bit. Come time for a replacement I wanted to get a new keytronic as I had no problems, but I erroneously purchased a 'slim' version where the keys themselves were very short and the distance to actuation, I think (can't be sure anymore) is a shallower compared to their full size ones.
I don't really mind this keyboard, but sometimes I can't help but think I can do a bit better. So I'm looking for a mechanical.
I've pretty much set my sights on something with Cherry Blues, so I'm good as far as that goes.
However the spacebar is something that worries me. One thing I really like about this keyboard is that it has three actual rubber domes placed at the right, middle, and left side of the spacebar. The end result is that no matter where I press it, it will always smoothly actuate and will never sort of 'lock' up compared to cheap OEMs like Dells that only have a button in the middle of the spacebar.
Does this locking problem happen on keyboards with stabilizers? I imagine that it could if you press the extreme ends of the spacebar, but for this particular keytronic it really isn't an issue.
I can take pics on request.
Offline bladamson
« Reply #1 on: Tue, 28 December 2010, 12:43:09 »
Nope.
I'm typing this on a Model M that is full of cat hair, crumbs, coffee grounds, staples, ash, hardened lava, reinforced concrete, yeti droppings, and the odd bit of unidentifiable radioactive funk of extraterrestrial origin.  The spacebar works smoothly and perfectly at either edge.
I've had some trouble with the shifts, but they don't have stabilizer bars, just plastic guides.  I expect that this could be remedied by cleaning the keyboard more than once every 5 years, though.
I never had any spacebar trouble with any of my mechanical apple keyboards in the years past, either.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Tue, 28 December 2010, 13:26:42 »
Quote from: bladamson;269853
Either that, or the board needs a nuts/bolts mod or has a cracked barrel plate. These plastic inserts are a little fussy.
Is there anything known about the health implications of yeti droppings? :p
Anyway, stabilizers may be noisy (depending on construction), but usually they get the job done perfectly fine. Not sure about the all-plastic ones found in cheapo keyboards, but those with metal wire certainly do.
Offline msiegel
« Reply #3 on: Tue, 28 December 2010, 13:34:41 »
Quote from: keyb_gr;269869
what goes wrong with them?
i'm planning on using 10 of them in a mod :-S
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #4 on: Tue, 28 December 2010, 13:55:33 »
If you liked the big old Keytronics, than an IBM Model M is definitely perfect for you.
Offline bladamson
« Reply #5 on: Tue, 28 December 2010, 14:39:58 »
And you can still get brand new ones (albeit rebadged) at a decent price.
Offline bladamson
« Reply #6 on: Tue, 28 December 2010, 14:43:56 »
Hm!  I shall have to tear it apart once my F gets here and goes into service. :3
That might explain why Elvis talks to me in my head.
Offline killy
« Reply #7 on: Tue, 28 December 2010, 14:49:22 »
Quote from: microsoft windows;269887
Quote from: bladamson;269901
I actually have a model M downstairs, I believe. But it has a funny output, and I don't have the funny output to PS/2 adapter cable.
Problem is I think the model M is a bit loud and a bit stiff, so that's why I think I will try Cherry Blues. I decided against the Blackwidow as I read that it only has a single button in the middle and no stabilizers. I saw the ducky and I was interested, but no idea how good stabilizers are versus having real keys.
The rosewill RK9000 seems to have three keys (or one key + two stabilizers), I'm not sure since no one has popped their spacebar in a review I read.
I am considering waiting for EK's new stuff.
Offline killy
« Reply #8 on: Tue, 28 December 2010, 15:01:27 »
From what I remember, it looked like an s-video input. Although I just checked, and I think someone tossed it out =\. Oh well.
That and I sort of appreciate the window key, I do frequently use it for shortcuts.
Offline Pylon
« Reply #9 on: Tue, 28 December 2010, 15:31:25 »
Quote from: killy;269913
Then a Unicomp is for you.
Offline killy
« Reply #10 on: Tue, 28 December 2010, 15:39:24 »
I got to poke the blackwidow keys at a computer store so I want to try Blues, as FWIW the buckling springs are just a bit too loud. My main question was whether stabilizers would distribute the load evenly compared to having three real buttons spread out under the space bar, as I game with the WASD cluster.
