Author Topic: Trackball users:  (Read 12241 times)
Offline snerd
Trackball users:
« on: Wed, 29 December 2010, 09:37:32 »
I recently got a CST laser trackball due to some pain welling up in my wrists (primarily the mouse side). I am finding that the trackball does not work for the way I interact with my computer, and here's why:
I like having every window showing on my screen. I have 2550x1440 + 1900x1200 pixels and I'm constantly moving my main focus to right in front of me, and moving other windows around to the periphery and resizing things absentmindedly. I find that clicking and dragging is such a chore with the trackball. Especially to get something over to the other monitor.  It takes holding the button down with my thumb, and contorting my hand about 5 times to get a window moved.
Do trackball users have a different way of doing this? Sticky clicks or something?
The other problem I have with it is that it's not as smooth as I was hoping it would be. especially moving diagonally, the rollers get jammed sometimes, and there is sometimes a bumping when I'm rolling around. I wonder if it's defective.
  • Live long and prosper
Trackball users:
« Reply #1 on: Wed, 29 December 2010, 09:50:07 »
I have an old IBM Track Point L40 trackball mouse and it has the "click and hold" buttons, is that kinda what your looking for?
Looks like this:
« Last Edit: Wed, 29 December 2010, 09:58:50 by Computer-Lab in Basement »
tp thread is tp thread
Offline snerd
Trackball users:
« Reply #2 on: Wed, 29 December 2010, 10:04:13 »
Quote from: Computer-Lab in Basement;270282
Looks like this:
Interesting. I was thinking more of a software option that was "click and hold" depending on what you click on, but it does make sense to have an extra button.
woody
  •  Guest
Trackball users:
« Reply #3 on: Wed, 29 December 2010, 10:08:34 »
Or assign some keyboard keys as mouse buttons.
Offline MsKeyboard
Trackball users:
« Reply #4 on: Wed, 29 December 2010, 10:10:06 »
The CST trackballs are typically high quality products, so if you are having problems there might be an issue, maybe some dust or grit.  Sometimes a blast of air will do the trick.
Also, these trackballs are programmable, to an extent.  Click-lock is one of the functions that comes standard, so you may want to give that a try, like CL in Basement suggested.
Trackballs typically require a bit of a learning curve.  Once most people become comfortable with them it becomes very hard to go back to the standard mouse design.  Of course, YMMV............
Good luck with your trackball, just don't give up too soon.....Later
Offline theferenc
Trackball users:
« Reply #5 on: Wed, 29 December 2010, 10:24:28 »
You also might want to adjust the speed (in software) or the precision (hardware). I have 4 screens (1600x1200), and have no problem flicking across all of them in one spin.
Also, keep in mind the whole left side is the mouse button, basically. Push on the bottom of it with your thumb, which, at least for me, puts the ball directly under my fingers.
Just keep using it, and it will become easier. I love my CST.
Offline jpc
Trackball users:
« Reply #6 on: Wed, 29 December 2010, 10:31:02 »
snerd, you're not alone. I have never been happy with the CST trackball.
CST Sin #1: The wedge shape forces you to angle your hand up toward the ceiling (dorsiflexion) which is going to be uncomfortable sooner or later. You could fix the dorsiflexion by adding a palm rest to elevate your palm, except . . .
CST Sin #2: The same wedge shape prevents you from using a palm rest. The thin end of the wedge occupies the space where the palm rest should be.
CST Sin #3: The rollers are a bit sticky. The Kensington Expert Mouse requires less effort to roll the ball, as does the Logitech TrackMan.
CST Sin #4: the buttons are stiff. (Near the top of the CST, they are not so stiff; but down around where your thumb and pinky will be, they are stiff.) The Kensington Expert Mouse has buttons that are easy to click. As does the Logitech TrackMan.
Ultimately I modded my CST, relocating the cord so that I could rotate the device 180 degrees, with the thin end of the wedge pointing away from me. Then you can use software to invert the axes and swap the buttons. This fixes sin #4, because with the device rotated, you are pressing the buttons at the "easy" end, and it fixes sin #2, because now you can add the missing palm rest. Sin #3 remains. Inverting axes and buttons in software is a PITA and might not work in every OS.
My daily drivers are a Kensington Expert Mouse and a Logitech TrackMan. They're better than the CST in every way that matters for ergonomics and usability.
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline jpc
Trackball users:
« Reply #7 on: Wed, 29 December 2010, 10:32:27 »
Quote from: woody;270287
+1
Offline snerd
Trackball users:
« Reply #8 on: Wed, 29 December 2010, 10:40:02 »
Quote from: jpc;270294
+1
This makes a lot of sense. I like keeping my hands on the keyboard as much as possible. Also kind of wishing I got the model that takes extra buttons. I would run a dedicated button over to the other side of my KB.
Offline jpc
Trackball users:
« Reply #9 on: Wed, 29 December 2010, 10:41:36 »
My CST review has a recipe for binding keys to mouse buttons in Linux.
Offline theferenc
Trackball users:
« Reply #10 on: Wed, 29 December 2010, 11:07:12 »
It works just as well with the HHKB, as a matter of fact. Try not to let your prejudices run away with you too often.
There are X mods that allow most of those commands to work in Linux, as well. They might be KDE or Gnome specific, though. I've only ever used them with KDE.
woody
  •  Guest
Trackball users:
« Reply #11 on: Wed, 29 December 2010, 12:51:08 »
Logitech's diNovo Edge has a left-click and some zoom mouse buttons left to the alphanumeric cluster. There are left and right-click mouse buttons below the touchpad. And you can of course click by touching the pad.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Trackball users:
« Reply #12 on: Wed, 29 December 2010, 13:20:03 »
Quote from: jpc;270293
I like the Kensington Expert trackballs. They're nice and smooth, and got a neat scroll wheel around the tracking ball.
Offline RoboKrikit
Trackball users:
« Reply #13 on: Wed, 29 December 2010, 14:25:53 »
I use a Kensington Expert Mouse.  The buttons are designed to be pretty easy to click in different hand positions, and the scroll wheel is around the ball so you don't have to reach up to scroll, or keep your hand in a higher position.
The only thing keeping me from trying out a CST is the scroll wheel placement.  I tend to keep my fingertips on the ball, and the angle that my hand sits at would require me to lift my hand to stretch my fingers forward to hit the scroll wheel, instead of lazily flicking the scroll wheel with my thumb.  I think this could be ameliorated by using a keyboard tray or lower desk, which are still on my to-do list.
The scrollwheel in the Kensington is grindy though.  Its design is flawed from a hand-feel perspective, but it does work pretty well in function.
Edit: If by smoothness you mean that the ball itself does not move very smoothly, if it is new it may not be properly, erm, lubricated yet.  It will break in eventually.  You can speed this up easily, but I will say no more.  Dirty secret of trackball users, you see.
« Last Edit: Wed, 29 December 2010, 14:30:23 by RoboKrikit »
Lovely day for a GUINNESS
Offline kidchunks
Trackball users:
« Reply #14 on: Wed, 29 December 2010, 15:03:54 »
Quote from: RoboKrikit;270377
Did you remove the magnet? Was it still grindy?
I tried the trackman and it was pretty sweet. I ended up taking it back because I couldn't do precision designing with it (didn't give it enough of a try). I may end up grabbing it again.
« Last Edit: Wed, 29 December 2010, 15:07:38 by kidchunks »
Topre || BS > *
my root : kidchunks[dot]com
Offline woebtz
    • http://www.headcasegames.com
ShiftIt for Mac
« Reply #15 on: Wed, 29 December 2010, 15:03:57 »
Quote from: ripster;270299
WIN + Arrow keys = Win!
(assuming you have Windows 7 and not a HHKB)
:thumb:
Also, Autohotkey, if you're on XP or Vista (Caps Lock + WASD!):
http://lifehacker.com/5133039/windows-7-shortcuts-enables-the-best-win7-shortcuts-in-xp-or-vista
Or ShiftIt on Mac (see Filip Krikava's github > Download > 1.5):
http://code.google.com/p/shiftit/
@jpc: Ouch. I was planning to save up for the L-Trac-X to replace the KEM I've never been too happy about... :/
@snerd: Is your pain from holding/moving the mouse or from clicking the buttons?
Filco Majestouch Tenkeyless CB, Apple Wired Keyboard, MS Comfort Curve 2000, Belkin n52te,
RollerMouse Pro, Ergonomic Touchpad, Magic Trackpad, Kensington Expert, Orbit Trackball w/ Scroll, IBM Scrollpoint III, Zalman FPSGun, Monster Gecko PistolMouse, Logitech TrackMan Wheel, Marble & First Pilot
[/COLOR]
Offline snerd
Trackball users:
« Reply #16 on: Wed, 29 December 2010, 15:17:05 »
Quote from: woebtz;270397
I would say it's from holding the mouse. I have really large hands, and you should see the claw that is formed. Especially the thumb and pinky curling in to move the mouse side to side accurately. The problem started when I got a G500, but I don't know what mouse would be better. That one is pretty big, and I like everything about it except of course this major issue.
Actually my wrists have felt better since I started splitting time with the trackball and I also took the optional weights out of the mouse.
Offline Levoc
Trackball users:
« Reply #17 on: Wed, 29 December 2010, 16:38:19 »
I'd have to agree with Snerd. I picked up a LTRACX Large Trackball back at the end of October from Fentek and have been using it for about two months now. Having issues with my wrist being more in pain from the positioning then with a typical mouse. And that's with tilting and angeling the trackball in various attempts to make it more comfortable. I've also found that my thumb gets tired when clicking a lot or trying to click and drag.
So if anyone wants to buy a black trackball with 800, 1600, 2400, 3200 CPI I'd be happy to toss it up on eBay with a buyout around $150. It also has the two jacks at the top for additional buttons. =)
Offline snerd
Trackball users:
« Reply #18 on: Wed, 29 December 2010, 17:29:47 »
I am now in love with these shortcuts. I guess after a 8 windows versions, you stop looking for what's new. Thanks!
Offline theferenc
Trackball users:
« Reply #19 on: Wed, 29 December 2010, 20:08:08 »
I find that if I put my LTracX over my number pad, it feels better. If I don't have it there, I have it at a slight angle to my keyboard.
It's also on my desk, so is relatively here. There isn't really any backward flexing of my wrist. If I rest my elbows on the arms of my chair (with the arms turned in), it's the perfect angle.
Offline theferenc
Trackball users:
« Reply #20 on: Wed, 29 December 2010, 20:27:44 »
1) Awesome picture. I especially love the use of the windows key at the end. You should put a shift key plus a 1 there for chuckles.
2) As I stated before, it works on the HHKB.
3) There are many reasons the HHKB won't be a mainstream keyboard, most shared with the realforces. This is not one of the reasons.
I'm done correcting you though. Feel free to be wrong as much as you like.
Trackball users:
« Reply #21 on: Wed, 29 December 2010, 20:28:19 »
You're right. Windows is the winner!
Offline Milquetoast
Trackball users:
« Reply #22 on: Fri, 31 December 2010, 04:34:11 »
I've found that the "grindyness" of the scroll ring goes away with use, even without taking the magnets out. In fact, I prefer the magnets in because the "notch" effect provides some feedback.
I think the scroll ring idea was a stroke of genius on the part of the Kensington engineers.
Offline RoboKrikit
Trackball users:
« Reply #23 on: Fri, 31 December 2010, 14:50:24 »
Quote from: Milquetoast;271086
Next month I'll have had the Expert Mouse for 4 years.  Its grindiness is not going anywhere soon.  I leave the magnets in for the feedback also.
