Author Topic: what is scroll lock actually for?  (Read 3849 times)
Offline fssbzz
« on: Sat, 01 January 2011, 01:22:20 »
i turn on and off.
nothing happen
my scrolling still works fine.
even on or off.
but does it actually do?
Offline bladamson
« Reply #1 on: Sat, 01 January 2011, 01:31:02 »
I think in DOS is used to actually stop the screen from scrolling. :P
But now it just provides an extra LED to make blink when you have mail or something. :P
Offline fssbzz
« Reply #2 on: Sat, 01 January 2011, 01:31:43 »
so in windows, it really does nothing other then give you some cool LED?
Offline bladamson
« Reply #3 on: Sat, 01 January 2011, 01:37:39 »
Not that I know of. :3
Offline bladamson
« Reply #4 on: Sat, 01 January 2011, 01:40:23 »
Does is launch Doom?
Offline fssbzz
« Reply #5 on: Sat, 01 January 2011, 01:43:37 »
Quote from: ripster;271490
Load up Excel and try it.
oh man, i see the difference now.
thanks!
Offline Minskleip
« Reply #6 on: Sat, 01 January 2011, 05:10:31 »
Now think if these programs had a decent editor, like Vi!
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline Sam
« Reply #7 on: Sat, 01 January 2011, 07:08:35 »
It was intended to give a way of keeping the cursor positioned in the same place on the screen when pressing up/down arrow and having the screen scroll up/down a line rather than move the cursor.  Seems though it's not so commonly used anymore in modern applications.  Some applications treat the mouse scroll wheel in this same manner.  I suppose most people found it not very useful and applications started ignoring it, especially after the mouse became standard on computers and one could just click on the up/down arrows on the scroll bar.  I would often use it if I was reading a lengthy piece of text, where I might want to scroll down as I read, but sometimes scroll back up a line or two to check something I previously read.  When doing this via only a keyboard it's a handy feature to have.  Page up/down would work, but it's easier to lose your place for a moment compared to seeing just a single line scrolling.
Offline ch_123
« Reply #8 on: Sat, 01 January 2011, 07:21:18 »
I think it's used in Linux to control the flow of text on a console.
Offline Minskleip
« Reply #9 on: Sat, 01 January 2011, 07:36:30 »
Quote from: ch_123;271552
Do you have a box handy to test if it has any effect in vi? Or tmux!?
Offline 7bit
  • MX1A-G1DW
« Reply #10 on: Sat, 01 January 2011, 08:09:28 »
Quote from: Minskleip;271553
It only works in a text console, by stopping output.
It does not work in a X11 terminal emulation.
It was useful in times when output had been printed on endless paper.
Nowadays it is 100% anachronistic. I use that button as Caps Lock.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Minskleip
« Reply #11 on: Sat, 01 January 2011, 08:49:55 »
Quote from: 7bit;271555
Ah, ok. Don't think I have caps lock on Linux anymore
Offline theferenc
« Reply #12 on: Sat, 01 January 2011, 09:31:33 »
My caps lock is where ESC usually lives. It's nice and out of the way, and I didn't have to give up another key to do it, since that's a dead key in the UNIX layout.
Also, emacs recognizes scroll lock, for what it's worth. At least in my departmental installation (RHEL).
Offline Daniel Beaver
« Reply #13 on: Sat, 01 January 2011, 11:25:07 »
The legitimate uses have been mentioned.
But what it's really for is having a super handy on/off light for scripts you run.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #14 on: Sun, 02 January 2011, 02:51:29 »
haahaa... This ^^^
Seriously, it's a great key for that!
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
