Author Topic: X-keysŪ Professional (58 Keys) USB  (Read 3613 times)
Offline Ekaros
  • Trade Count: (0)
« on: Tue, 04 January 2011, 09:38:58 »
Re selling this time as I don't have too much use for it in future.
http://www.xkeys.com/xkeys/xkpro.php Info on later model
A few issue:
NO ACCESSORIES!
Item is in working order, missing two top-caps from relegendable keys, also one other is in bad shape. Likely easy to find replacement, as switches are brown MX.
Other issue with item is the compability, only programmable under Win XP/2000 should work with Vista and 7 after programmed.
Also there is some parts of casing broken/(ing) and it's bit dirty.
40€+shipping
Also trade for MX Clear ISO-board.
If nothing else 58 MX Brown Switch and 55 two part keycaps ;D
« Last Edit: Fri, 25 February 2011, 16:37:00 by Ekaros »
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Ekaros
  • Trade Count: (0)
« Reply #1 on: Wed, 19 January 2011, 09:37:04 »
Priced dropped. Also other boards considered for swap...
« Last Edit: Wed, 19 January 2011, 10:29:59 by Ekaros »
[SIGPIC][/SIGPIC]
Offline Ekaros
  • Trade Count: (0)
« Reply #2 on: Sat, 12 February 2011, 17:04:39 »
« Last Edit: Sat, 12 February 2011, 17:48:31 by Ekaros »
[SIGPIC][/SIGPIC]
Offline Ekaros
  • Trade Count: (0)
« Reply #3 on: Fri, 25 February 2011, 16:36:52 »
One more bumb.
[SIGPIC][/SIGPIC]
