Author Topic: Post your TV remotes  (Read 9780 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Thu, 06 January 2011, 18:50:21 »
What kind of TV remote do you use? I've been using this all-in-one rubber dome TV remote for a while.
  • Live long and prosper
« Reply #1 on: Thu, 06 January 2011, 19:12:23 »
You have a TV? I would think you would only have radio.
tp thread is tp thread
« Reply #2 on: Thu, 06 January 2011, 20:00:03 »
Quote from: Computer-Lab in Basement;274260
I've had a TV for years. But I've never bothered with cable.
That's a cool radio though. I like those AM dials. Wonder how many vacuum tubes it's got?
« Reply #3 on: Thu, 06 January 2011, 20:25:15 »
Quote from: microsoft windows;274285
My dad has at least 3 radios like that and at least 20 other vacuum tube radios at his house in NY.  Some of the big ones have record players in them.
woody
  •  Guest
« Reply #4 on: Fri, 07 January 2011, 05:12:24 »
Not mine, but perhaps interesting to remote consumers.
Offline db_Iodine
« Reply #5 on: Fri, 07 January 2011, 06:47:17 »
A little NSFW so I edited this to be just a link to the picture.
« Last Edit: Fri, 07 January 2011, 06:49:25 by db_Iodine »
[SIGPIC][/SIGPIC]
Offline firestorm
« Reply #6 on: Fri, 07 January 2011, 07:22:42 »
I've actually been more picky about remotes than I have keyboards.  Part of it is tactile feel too though.
We're back to using the old faithful Home Theater Master (was the consumer brand for Universal Remote Control) MX-500.
I tried out a Logitech Harmony 700, but it felt cheap and I was annoyed by having to plug it in to recharge it frequently.  The button layout is improved for Harmony, but remains sub par compared to others.  I wasn't impressed by button feel either.
Then I tried the Harmony One.  It had a similar button feeland the button layout was virtually the same.  Battery charging was easier, since it had a docking station and it had Lithium Ion batteries vs. NiMH in the 700.  I probably could have lived with the Harmony One, since it performed well enough.  I was able to get the "macros" to work satisfactorily.  What I really hated was the touch screen.  Every time I wanted to use a non-standard (i.e. non hard button) feature, I had to look at the damn screen.  e.g. DVR button.  It also felt like it would break if it were ever dropped or sat on.
Our MX-500 is fairly old, and it doesn't work with the newer IR protocol used by some cable boxes.  I'm not happy with the AT&T U-Verse picture quality or DVR software in the first place, but of course my MX-500 doesn't work with it either.  I've managed to get half the DVR buttons work, through persistence, but that's it.  Otherwise, the MX-500 is built 10x better than the Harmony remotes, with a better tactile feel (buttons and layout.)
For now, I returned the Logitech remotes and bought a photo backpack instead.  I'm trying to decide between settling for the URC R50 (essentially replaced the MX-500), going for the MX-450 or higher, or simply waiting until a better option magically appears.
« Reply #7 on: Fri, 07 January 2011, 12:52:37 »
Just imagine if that was a TV screen in that remote.
Offline 7bit
  • MX1A-G1DW
« Reply #8 on: Fri, 07 January 2011, 14:22:31 »
Those ^^^ are lame!
This one is the real thing:
Outside for normal operation:
Inside for entering text:
Please notice that it has got more keys than an IBM 122-key terminal board!
Even though it is larger than ususal remote controls, 2 batteries are sufficient:
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline phillip
« Reply #9 on: Fri, 07 January 2011, 15:27:33 »
the ones for the bedroom tvs
Offline pfink
« Reply #10 on: Fri, 07 January 2011, 15:32:57 »
Quote from: microsoft windows;274248
Wow. I thought you'd have one of these:
I'm using this thing:
Offline firestorm
« Reply #11 on: Fri, 07 January 2011, 15:43:07 »
Quote from: ripster;274743
I found the Harmony One buttons pretty tactile.
The layout provides OK tactility as far as locating buttons by feel, but button feel (i.e. switch action) is very disappointing compared to the MX-500, which I paid $80 for 6-7 years ago.  I don't like the stiffness nor the "crack" of the tactile bump on the Harmony remotes.  The MX-500 just has a nice tactile bump, and there's no mistaking when pushing through it.  Key action is soft, yet relative easy to avoid accidental activation.  It's much nicer for "30 sec skip" on DVR's IMO.
Still, my gripe was with the complete lack of tactility with the touch screen.  If it had 6 physical buttons instead, I would have been fine with it.  And it probably would be $50 cheaper, which would remedy the fact that I think it feels too cheap for even the $160 I paid for it.
Also, the HTM/URC remotes have IR cannons on them.  Mine can shoot through blankets and some pillows.  It magically bends IR light around corners too.
Offline db_Iodine
« Reply #12 on: Fri, 07 January 2011, 15:43:17 »
Quote from: Julle;274487
Is it universal, or do you have one for each device?
A man can't live with only one remote, so no, it's not universal.
[SIGPIC][/SIGPIC]
« Reply #13 on: Sat, 08 January 2011, 09:22:48 »
My remote's a universal. It controls both the TV and the VCR.
Offline Daniel Beaver
« Reply #14 on: Sat, 08 January 2011, 09:34:59 »
I haven't owned a TV for a couple of years now. But when I did, I used a Logitech Harmony remote. I distinctly remember it sucking.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline 2084
« Reply #15 on: Sat, 08 January 2011, 10:30:40 »
Best remote I owned was this Metz 6203, unfortunately the tv died long ago
simple, intuitive and good feel
woody
  •  Guest
« Reply #16 on: Sat, 08 January 2011, 19:05:12 »
Quote from: Daniel Beaver;275139
Few more years, and it will be two decades without TV for me. Feels good.
Offline phillip
« Reply #17 on: Sun, 09 January 2011, 11:53:34 »
so do you guys not watch movies?  or do you have projectors?
Offline instantkamera
« Reply #18 on: Sun, 09 January 2011, 16:28:50 »
Quote from: woody;275448
I have news for you, fellow internet surfer ...
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
woody
  •  Guest
« Reply #19 on: Sun, 09 January 2011, 16:40:44 »
Quote from: instantkamera;275831
Go on, my brother. I don't surf the net for news.
What's new?
Offline keyboardlover
« Reply #20 on: Sun, 09 January 2011, 16:45:30 »
Quote from: woody;275836
What's new?
For one thing, we have begun to colonise mars.
woody
  •  Guest
« Reply #21 on: Sun, 09 January 2011, 16:47:52 »
Quote from: keyboardlover;275839
I will repost specially for you:
Enjoy!
Offline Lanx
« Reply #22 on: Sun, 09 January 2011, 17:44:39 »
Ipod touch controls my htpc.
Quote from: phillip;275738
I got another wife angry at me, her and her husband came over to play the kinect and he says he's been obsessed with the thought of a projector ever since they saw my setup.
Of course they'll never do it they don't have a basement and she'll never let him turn a room into a projector place.
« Reply #23 on: Mon, 10 January 2011, 08:44:53 »
What's new?
No, but if you are telling me you aren't entertained by the internet and your computer in general, Im inclined to call BS.
Entertainment delivered via a screen to the consumers eyes ... how is it any different?
woody
  •  Guest
« Reply #24 on: Mon, 10 January 2011, 15:09:29 »
Entertained - kinda, if you count listening to music, etc., but no news. My computer is just a tool.
Offline Jerri
« Reply #25 on: Tue, 11 January 2011, 06:26:36 »
Here are my remotes. The one i like most is the one from the Pioneer BDP. The Wadia "brick" is ok, too. But the one i hate is that for the XRGB-3! And the most "tactility" (hope that word is right) has the sony.
« Last Edit: Tue, 11 January 2011, 06:29:17 by Jerri »
You can take the man out of the 80's, but you can't take the 80's out of the man.
« Reply #26 on: Tue, 18 January 2011, 18:41:37 »
You all are a bunch of geeks who know about input devices and you still don't have universal remotes!
« Reply #27 on: Tue, 18 January 2011, 19:50:33 »
MW, I think you should start a new troll poll!
« Reply #28 on: Tue, 18 January 2011, 20:23:35 »
Quote from: ripster;280747
Where's the MUTE!!!
With over 25,000 posts, I never thought you'd know what that was!
« Reply #29 on: Tue, 18 January 2011, 20:47:53 »
We all already knew you were a wise guy.
Offline itlnstln
« Reply #30 on: Wed, 19 January 2011, 06:44:10 »
Yoo talkin' to me???
MW doesn't have to worry about me.  He's got someone new going after his crown: piotrek.
Offline db_Iodine
« Reply #31 on: Wed, 19 January 2011, 07:18:24 »
A lot of topics getting derailed lately. I shall put this one back on track.
This is certainly my all time favorite remote.
[SIGPIC][/SIGPIC]
Offline itlnstln
« Reply #32 on: Wed, 19 January 2011, 07:59:42 »
I like the Harmony remotes.  I have an old-school 880, and I love it.  The only (good) problem I have with it is that I can't find a reason to upgrade.
Offline db_Iodine
« Reply #33 on: Wed, 19 January 2011, 08:24:17 »
I think I'd be fine with something like Harmony 555, but I got the Harmony One at a great price. It was only €25 more than the cheapest 555 I could find.
[SIGPIC][/SIGPIC]
woody
  •  Guest
« Reply #34 on: Thu, 20 January 2011, 16:07:15 »
So if you play with this, does it make it a Glockenspiel?
« Reply #35 on: Thu, 20 January 2011, 17:32:47 »
Quote from: ripster;281911
Not the most politically correct right now.  A Glock.
I'm pretty certain it's photoshop.  The Gangsta Booty mouse pic is right next to it.
It would be funny if the trigger was a "Mute" button.
« Reply #36 on: Thu, 20 January 2011, 17:55:46 »
When I was a kid my TV never had a remote.
Offline msiegel
« Reply #37 on: Thu, 20 January 2011, 18:10:19 »
"good engineering is not funny" (read in austrian governator voice)
Offline ffarysam
« Reply #38 on: Fri, 21 January 2011, 20:30:10 »
Not as many as mine.
