Author Topic: How is it feels Cherry MX Blue + mx brown 45g Spring?  (Read 3742 times)
Offline fssbzz
« on: Sat, 08 January 2011, 15:48:42 »
will it still be clicky?
anyone try this before?
thanks
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #1 on: Sat, 08 January 2011, 16:00:57 »
Should feel about the same if not exactly the same. I believe the are the
same/similar spring. From what I remember they felt the same.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline fssbzz
« Reply #2 on: Sat, 08 January 2011, 16:03:00 »
lol no. brown and blue feel totally different to me.
i like the force needed to press on the brown but not on blue.
if blue is lighter like brown, it will be nice.
Offline Nadger
« Reply #3 on: Sat, 08 January 2011, 16:21:10 »
Edit: tossed them together in photoshop
brown looks like its got 1 more coil.
« Last Edit: Sat, 08 January 2011, 16:33:01 by Nadger »
● Logitech ♦ G600
● Noppoo ♦ Choc Mini 茶轴
● Plum ♦ 96 White / Red Switch
● Microsoft ♦ Xbox 360 Windows Controller
Offline clickclack
« Reply #4 on: Sat, 08 January 2011, 16:25:02 »
Quote from: fssbzz;275329
The switches should indeed feel different, not the springs within them.
The blue switch has a slightly higher activation force likely do to the slightly more pronounce plastic bump in the floating stem. If the spring is different, it should only be barely noticeable, barely.
« Last Edit: Sat, 08 January 2011, 16:27:55 by clickclack »
Offline calavera
« Reply #5 on: Sat, 08 January 2011, 19:47:49 »
I have a black switch + brown springs combo that I love. It was quite popular in S.Korea. I also have a white switch + brown springs combo that feels similar to cherry blues but has less of a "click"...it's hard to explain. I think nobody does blue switch with brown springs because the difference is just too small to notice.
edit: If I remember correctly the pressure goes as follows
black= 70~85g
blue = 60g
brown = 55g
red = 45g
« Last Edit: Sat, 08 January 2011, 20:05:17 by calavera »
Offline dec.net
« Reply #6 on: Sun, 09 January 2011, 07:43:27 »
um, these springs do look very much alike and I guess it could be reasonably assumed that Cherry corp is into saving money by using one spring for two different tactile switches... But since spring actions often depends more on the actual spring wire used than the number of coils, it would probably be the definitive end to all guesswork if one could take a photo of the spring being compressed (or extended, if that's easier to accomplish) by a known force, with a readable ruler right next to it. Those are linear springs (as can be told by the regular intervals between coils) and thus one point in the force-compression or force-extension diagram would be enough to see if they are identical.
Which, by the way, brings me to another question... Question thread following.
Chris
Daily drivers at home: \'93 IBM Model M; Currently: Model F XT (hebrew layout), adapted via Teensy.
Daily driver at University: Marquardt HEROS miliary board.
Take-with-me-board: G80-1800 (blue/black).
Boards I don\'t use: DS 102W (cherry 1800 lookalike, waterproof industrial case with ultra-mushy membrane switches). Dell AT102W (don\'t like it too much, very uneven feeling - last chance is to teflon-coat the sliders)
Offline Nadger
« Reply #7 on: Sun, 09 January 2011, 18:45:00 »
Is there a spring ligher?  Reds are the same spring arrant they?
● Logitech ♦ G600
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #8 on: Sun, 09 January 2011, 19:37:06 »
Yes, Reds are the same spring.
If you want lighter, you'll need either a 30g Topre, something like a DataHand, or mod yourself a Cherry MY board to 20g.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
