Author Topic: How exactly do cherry switches work?  (Read 2816 times)
Offline maximus20895
« on: Sat, 08 January 2011, 17:34:16 »
I am pretty new to mechanical keyboards in general and to be honest I have never even used one. I have read the mechanical switch guide and most other wikis, but I still don't know exactly how the switches work.
I don't know what they look like inside, or how it sends a signal, or how the brown, blue, black, white, etc differ physical from one another.
Is there a post that shows the ground work of switches or anything of the sort?
Offline Pylon
« Reply #1 on: Sat, 08 January 2011, 18:09:09 »
You could look through the Wiki.
http://geekhack.org/showwiki.php?title=Cherry+switches+and+boards
This is how blues work apparently:
http://park16.wakwak.com/~ex4/kb/tech/cherry_mx_click.swf
The yellow parts are the electrical contacts. I can kind of see how it works, but I understand the Alps and buckling spring mechanisms  better.
« Last Edit: Sat, 08 January 2011, 18:40:07 by Pylon »
Offline Pylon
« Reply #2 on: Sat, 08 January 2011, 18:09:41 »
Hmm we should start a "how switches work" wiki article.
Offline msiegel
« Reply #3 on: Sat, 08 January 2011, 18:12:59 »
with links to patents in it? that would be cool :)
Offline laden3
« Reply #4 on: Sat, 08 January 2011, 18:33:02 »
Quote from: Pylon;275410
but I understand the Alps and buckling spring mechanisms work better.
Please elucidate. IIRC alps have shorter lifespan.
I rrrove brrracks.
Offline nanu
    • http://T-T.be/portal
« Reply #5 on: Sat, 08 January 2011, 18:34:22 »
They are simple switches. Normally open, and closed when you press a key down. If you dissemble a switch, removing the plunger, the circuit closes.
As mentioned by Pylon, the wiki page is useful. Linked there is Qwerter's Clinic, which in pictures explains it.
http://park16.wakwak.com/~ex4/kb/tech_cherry_mx.htm
Check out the graphic for how the Brown MX actuates, and the comparison of other switch profiles. The plungers determine the actuation characteristics, when combined with a certain spring.
Offline Pylon
« Reply #6 on: Sat, 08 January 2011, 18:40:49 »
Quote from: laden3;275420
Stupid typo on my part (edited). I meant that I have a better understanding of how they work compared to Cherries.
