Author Topic: Cherry G80-1865, anyone have this board?  (Read 19709 times)
Offline nocturn4l3030
« on: Sun, 09 January 2011, 01:10:52 »
Did a search on here and only found one thread related to this board but didn't really have much info on it
it really seems like the best solution to my problem (a small keyboard tray, but i use the numberpad).. are these double shots?
was just wondering if the overall build of this board is of good quality to anyone that does have this board.  taobao is selling a bunch of these and i just got an estimate from obook and the board itself is $150, but altogether is $216.78
/cry
right now it's this or spend $100 less on the PLU87.. and am undecided atm.. but if anyone has this board can give me their opinions it might help my decision =)  thx
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline sixty
    • http://deskthority.net
« Reply #1 on: Sun, 09 January 2011, 01:22:51 »
This was one of those Asian special orders. This one should exist in at least 3 versions variants:
G80-1865LWNEU-2 (MX Blue, Nkey, USB-Hub, Lasered Keys)
G80-1865LXNEU-2 (MX Brown, Nkey, USB-Hub, Lasered keys)
G80-1865HXNEU-2 (MX Brown, No Nkey, USB-Hub, Doubleshots)
A fourth variant is supposed to exist with MX Blue and Doubleshots, but I have never seen it.
The board is based on the Raptor K1, meaning it comes iwth a USB port and full nkey rollover, depending on model. Quality is okay, as good as the modern Cherry boards get. Not as good as the vintage ones due to slightly thinner case, but still pretty good. It will last several years. I have a few G80-18xx that are 20 years old and still work fine.
« Reply #2 on: Mon, 10 January 2011, 00:49:37 »
Quote from: sixty;275562
thanks for this info.. i inquired bout the cherry blues.. disappointed about it not being doubleshots >.<  decisions decisions.. thanks again
[/strike]
[/SIZE]
Offline calavera
« Reply #3 on: Mon, 10 January 2011, 01:00:52 »
FYI, the model number gives it away what kind of key caps it uses. The letter after the model number in bold like this: G80-xxxxHxxx
P=printed
L=laser
H=double shot
S=dye sublimation
In most cases priced and sought after in that order as well. Dye sub being the best. HTH
Offline itlnstln
« Reply #4 on: Mon, 10 January 2011, 06:54:57 »
I have the 1863 (MX browns, double-shots), and it's a great 'board.  The only thing I didn't consider when I bought it was how much I use the page nav cluster.  Being above the numpad makes the 'board compact, but those keys, especially delete, become very far away.  The only other, minor thing to consider is that the 0 key on the numpad is shorter than normal layouts.  I usually press that key with my right index finger, so I end up pressing the right arrow often.  After a few minutes, I adjust to using my right middle finger on that key.  Otherwise, I find it to better quality than my G80-3000 just as a comparison.
Offline Fiasco
« Reply #5 on: Mon, 10 January 2011, 09:36:33 »
I have a special item:
G80-1865LYCRC-2 (MX Red, Nkey, USB-Hub, Lasered Keys ,Chinese traditional layout )
Offline sixty
« Reply #6 on: Mon, 10 January 2011, 09:58:02 »
Quote from: Fiasco;276095
Is that an official one or modded with the MX Red? Can't find any info about this on Google at all.
« Reply #7 on: Mon, 04 April 2011, 19:39:17 »
The Cherry G80-1865LXNEU2 is available in the US now with MX Brown Cherry Stems and 2 downstream USB Ports
You can order it from electronic component distributors now but if you call CDW, Tiger or Newegg  They have it available to them
The Cherry Datasheet
http://www.cherrycorp.com/english/keyboards/pdf/G80-1865_MX.pdf
Razer Ultimate Black Widow | Razer Lycassa | Razer Mamba | Cherry G80-3000 | Cherry G86-51400EUADAA
Offline Laggy-gaga
« Reply #8 on: Tue, 05 April 2011, 08:21:31 »
It was designed as full NKRO
but build-in HUB does not support ps/2
so it is 6KRO only...
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline Eclairz
« Reply #9 on: Tue, 05 April 2011, 09:04:13 »
i prefer the standard layout of the G80-3000 than my G80-1800 to be honest even if the build quality is worse. I use the page nav cluster too much so my fingers have to travel further just to use them.
The USB hub is only 1.1 in my Raptor K1(my variant of the G80-1800) so there might be a limit on speed, btw.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline gilgam
« Reply #10 on: Tue, 05 April 2011, 14:06:58 »
I don't find them on these sites
do you have a direct link ?
Thanks
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
« Reply #11 on: Tue, 05 April 2011, 16:02:16 »
Here is a link from Allied where you can order the G80-1865LXNEU2  It is the only US seller I could find online
http://www.alliedelec.com/search/productdetail.aspx?SKU=908SPEC&MPN=G801865LXNEU2
As for NewEgg - Provantage etc you have to call them they can special order this product Cherry has it in stock in the US.
I have no idea what different resellers will charge you.  If you call Cherry the will say $200 MSRP and you need to call CDW, Provantage  or whoever yourself.
But Look at the G80-3000 Some sites have it close to the MSRP of $130 Provantage has it for $85
http://www.provantage.com/cherry-electronics-g803000lsceu2~7CHER0K0.htm
Offline wanabe
« Reply #12 on: Tue, 05 April 2011, 16:04:19 »
Occupation
    Marketing
computerkeyboardguy do you work for cherry?  you seem to have a lot of backchannel info
Offline digitalleftovers
« Reply #13 on: Tue, 05 April 2011, 16:07:43 »
If you don't like the spreadout layout, filco has a similar layout.  I only learned about this recently:
I don't think you can get it in ansi, though.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline Eclairz
« Reply #14 on: Wed, 06 April 2011, 06:25:00 »
Quote from: digitalleftovers;325211
Which Filco model is this? I've never seen this layout before
Offline RiGS
« Reply #15 on: Wed, 06 April 2011, 08:46:51 »
That Filco/right shift is a bad asian joke.
« Reply #16 on: Wed, 06 April 2011, 13:40:18 »
Quote from: Eclairz;325479
Its the FKB100MNB. You can read about it here: http://www.filcochina.com/Products.asp?Bigclassname=ProductsJ&productname=FKB100MNB
I have never seen it any place but filcochina.com
Keyboards:
« Reply #17 on: Wed, 06 April 2011, 14:29:19 »
My favorite part is the location of the Pause/Break key.  Its all by itself next to the logo and lock lights, as if it is REALLY important.
Keyboards:
Offline imsto
    • imsto.cn
« Reply #18 on: Wed, 06 April 2011, 21:06:14 »
now, there's a kind of 1865 with red Cherry MX.
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline REVENGE
« Reply #19 on: Tue, 26 April 2011, 03:15:10 »
Has anyone managed to get a quote or order the G80-1865 from ProVantage or elsewhere? Lowest price I've found in the US is $140 before shipping, which isn't bad compared to PCHome. On a side note, the 3000 is only $80 now from ProVantage.
« Reply #20 on: Tue, 26 April 2011, 12:20:54 »
Quote from: REVENGE;337380
Is the 3000 fully programmable?  I think the 1800 series are, and that may contribute to their higher price.
Keyboards:
Offline The Solutor
« Reply #21 on: Tue, 26 April 2011, 12:49:18 »
What a lovely keyboard this Filco mini  !!!
I want one of them asap.
« Reply #22 on: Tue, 26 April 2011, 13:19:46 »
Quote from: The Solutor;337580
I think you should PM Bruce or start a thread for interest on the Keyboard Co sub forum.  I'm sure he can get one for you.
Keyboards:
Offline REVENGE
« Reply #23 on: Tue, 26 April 2011, 13:27:40 »
Called Provantage and CDW and neither of them have sources in channel for this board, so the lowest cost after shipping and taxes I could find is $162.82, pretty much the same as PCHome prices.
Offline The Solutor
« Reply #24 on: Tue, 26 April 2011, 13:36:53 »
Quote from: digitalleftovers;337589
Too bad seem discontinued almost everywhere, anyway thanks for the suggestion
« Reply #25 on: Thu, 28 April 2011, 00:12:27 »
CHERRY 104-KEY CROSSPOINT KB USB/PS2
Mfg. Part: G801865LXNEU2  |  CDW Part: 2374907
Cherry Keyboards
Qty
$94.99
Advertised Price
Offline keyboardlover
« Reply #26 on: Thu, 28 April 2011, 08:41:52 »
I searched cdw and didn't see this keyboard. Will it be available in the future?
Offline REVENGE
« Reply #27 on: Thu, 05 May 2011, 16:58:14 »
Quote from: keyboardlover;338603
It's now available for backorder on CDW's website, ETA is around 3 - 4 weeks.
Offline dongkun
« Reply #28 on: Thu, 05 May 2011, 17:53:59 »
Quote from: sixty;276101
http://www.inpad.com.tw/goods.php?act=view&no=3666
1865 model - Win key, USB, blue LED ....Common Characteristics
« Reply #30 on: Sun, 19 June 2011, 19:54:12 »
Thanks for posting the link!
Offline grasshopper
« Reply #31 on: Sun, 18 September 2011, 06:09:03 »
Can someone tell me whether the switches on the g80-1865 are mounted on a metal plate.
Thanks
Offline N8N
« Reply #32 on: Sun, 18 September 2011, 06:25:24 »
I don't have the exact keyboard that you're referring to, but to my knowledge ALL Cherry G80 boards are PCB mount not plate mount.  someone please correct me if I'm mistaken...
Offline foliolio
« Reply #33 on: Sun, 18 September 2011, 09:10:08 »
There's also the LYNEU with MX reds & US ANSI layout.
« Reply #34 on: Sun, 18 September 2011, 12:16:54 »
Quote from: grasshopper;418059
Thanks
They are PCB-mounted, not plate-mounted. N8N is correct.
Offline grasshopper
« Reply #35 on: Sun, 18 September 2011, 14:59:02 »
Quote from: keyboardlover;418156
Pity. That's a deal breaker for me.
Offline PRISONER 24601
Re: Cherry G80-1865, anyone have this board?
« Reply #36 on: Thu, 07 May 2015, 15:49:11 »
My daily driver is an 1869 with blues. Love it. PCB > plate imho. Better sound, better feel.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline FrostyToast
  • Litshoard
« Reply #37 on: Thu, 07 May 2015, 16:34:27 »
Why would no plate be a deal breaker for you?
It means that you can swap out the sets and springs of the switches without any soldering.
That means you could just pick up a board with browns and change it to blues.
The feeling of PCB mount is also often preferred over plate mount.
Quote from: elton5354
