Author Topic: Removing Paint on 7G Keycaps  (Read 5458 times)
Offline Philth
« on: Mon, 10 January 2011, 11:28:23 »
Does anyone know the best way of removing the white paint on the 7G's engraved keycaps?
I'm experiencing what the 7G keys are notorious for: the paint rubbing off the keycaps. The WASD cluster has almost completely worn off. Just wondering if there was a way I could effectively strip all the key caps so that I'd at least get unifrom black-on-black engraved keycaps.
Thanks
Offline bpiphany
« Reply #1 on: Mon, 10 January 2011, 11:42:08 »
Offline Philth
« Reply #2 on: Mon, 10 January 2011, 11:54:06 »
^ Would probably work but I'm looking for more of a one-step chemical solution (like a solvent that won't damage the keys themselves, only remove the paint).
Offline Philth
« Reply #3 on: Mon, 10 January 2011, 13:01:56 »
Hmm so doesn't seem like theres an easy way, out of those solvents, to remove the lettering without damaging the plastic key itself.
I've heard somewhere that brake fluid as a solvent works for removing keycap lettering. Does anyone have any experience with that or am I going to have to bite the bullet and find out for myself?
Offline laden3
« Reply #4 on: Mon, 10 January 2011, 13:39:05 »
my suggestions:
-switch the keycaps with neighboring ones, takes a long time I think...
-rit dye them
I rrrove brrracks.
Offline stuiees
« Reply #5 on: Mon, 10 January 2011, 14:41:42 »
Quote from: Philth;276194
There is actually a chance this could work.  I know brake fluid can strip paint off a car, and I don't think it will damage most plastics (as long as it is not exposed for too long).  I have heard of people stripping paint off their hobby kits using this method.  I would try with just one key, let it soak for a bit, then dip a toothbrush into the fluid and scrub the cap lightly.  Also remember brake fluid is petrolium based, so it may take a good cleaning afterwards to get the keys "clean".  GL
I like Topre!
Offline Philth
« Reply #6 on: Mon, 10 January 2011, 15:08:17 »
Hah looks like I'm off to get some brake fluid for the sake of science! I'll post results (if there are any)
Offline itlnstln
« Reply #7 on: Mon, 10 January 2011, 15:12:55 »
For clarity, is it brake fluid or brake (parts) cleaner?  The latter would be a much more powerful solvent than the former.  I would exercise caution with the brake parts cleaner.
Offline guilleguillaume
« Reply #8 on: Mon, 10 January 2011, 15:14:20 »
I remember that when I used to paint Miniatures when I wanted to clean one made from plastic I putted it into a glass of Coke all the night and the next day the paint was just worn out.
I think this night I will try with one of my WASD keys since I use the Lavender Filco ones.
It will be fantastic to hace a "blank" 7G.
Anyway I can remember that someon in this forum used rubber like the one we use to erase pencil in paper and he nearly cleaned all the wite paint.
Offline Philth
« Reply #9 on: Mon, 10 January 2011, 15:27:55 »
Quote from: itlnstln;276246
Brake fluid. I'm almost convinced this will work. Here's some supportive cases:
1
2
3
Will try pencil eraser tonight. Will pick up brake fluid tomorrow
« Reply #10 on: Mon, 10 January 2011, 16:26:43 »
Well some people used Vinegar too clean the Old Miniatures and with the Coke (Coca-Cola) it does a good job.
I will try today or Tomorrow and will post pics.
Offline Philth
« Reply #11 on: Mon, 10 January 2011, 17:14:53 »
Regular rubber eraser definitely doesn't do the job.
