Author Topic: hhkb pro 2 versus hhkb jp ?  (Read 3251 times)
Offline gilgam
« on: Tue, 11 January 2011, 14:37:26 »
hi
first of all i want to thank you for all the good advices i found here.
I bought my first mechanical keyboard from Realforce and it's a real pleasure, an expensive one but a fantastic one.
So I'm considering buying a HHKB but there is two layouts the "normal" one and the japanese one with more keys, and a small space bar.
But is the quality the same ?
I've seen them  in geekstuff4u and benippon.
i'm waiting for the mini guru or the otd korean made one ;-) too but i never felt the cherry brown touch.
Thanks
Gilgam
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline eMps
« Reply #1 on: Tue, 11 January 2011, 14:54:57 »
I really like the small space bar. I always thought the big ones were way oversized and a waste of space. You can bind the JP-specific ones to something like backspace and give your underused thumb something to do.
Colemak since Jan. 10, 2011
Offline gilgam
« Reply #2 on: Tue, 11 January 2011, 15:07:16 »
ok the quality is the same, the spacebar is indeed small. I'm trying on my keyboard to type on the same space on the spacebar.
Small needles/spikes maybe ?
Offline itlnstln
« Reply #3 on: Tue, 11 January 2011, 15:17:58 »
Looking at my shiny spot, something tells me I would be pressing that circle-looking key a lot.
Offline itlnstln
« Reply #4 on: Tue, 11 January 2011, 15:22:20 »
You should check out my movie, then - The Loin King.
Offline bigpook
« Reply #5 on: Tue, 11 January 2011, 18:54:48 »
That short right shift key would not work for me at all....space bar would kill me too, judging from the shine on my space bar I would be hitting the kana key.
