Author Topic: My Tualatin Celeron for your Coppermine P3/Celeron  (Read 4432 times)
Offline kishy
  • Trade Count: (0)
  • Eye Bee M
    • http://kishy.ca/
« on: Fri, 14 January 2011, 18:50:17 »
Chip I have is a socket 370 Tualatin 1.1/100. May or may not work - I don't have a board that will take it.
I'm seeking a 100MHz FSB Celeron or P3 between 700MHz and 1GHz (preferably on the higher end). Cannot be a 133 or 66, has to be 100. Celeron vs P3 is relatively unimportant.
I don't know if the later chips were made available as Slot 1, but that would be suitable also - target mobo has both 370 and slot1.
Anyone have something suitable?
« Last Edit: Fri, 14 January 2011, 18:53:32 by kishy »
kishy.ca
Offline Half-Saint
  • Trade Count: (0)
« Reply #1 on: Sun, 16 January 2011, 11:28:37 »
Quote from: kishy;278771
I have a 700MHz Celeron but I'll have to check FSB first...
Sorry, it's 66Mhz...
« Last Edit: Sun, 16 January 2011, 12:09:48 by Half-Saint »
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline SmallFry
  • Trade Count: (0)
« Reply #2 on: Sun, 02 October 2011, 23:11:10 »
I have a celeron... I'll have to check everything but if it's right I'll sell it to u cheap
Offline Lenny_Nero
  • Trade Count: (0)
« Reply #3 on: Sun, 02 October 2011, 23:37:38 »
I will check,
As I have a load of 1U IBM and Compaq dual PIII 1400's,
and I am sure when I got them there were some with 866 and 1GHz chips in that I swapped out.
I just need to find them...
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087,  Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline Lenny_Nero
  • Trade Count: (0)
« Reply #4 on: Mon, 03 October 2011, 02:00:51 »
Yeah, the 1400 will not work.
I have had a quick look and not found them as yet,
a load of ECC memory was where I thought they were.
I got a feeling they are at my other place so I will try to get over there today.
Or at least check the spec, but I am sure the boards can run at all speeds depending on the settings.
But I try to take pictures of things I get like that so when I screw them up I can go back and see how they were setup :)
Offline Clickey
  • Trade Count: (0)
« Reply #5 on: Mon, 03 October 2011, 03:47:01 »
I used to live near Tualatin, it is a town south of Portland.
"we are on Geekhack not Lazy****" - The Solutor
Offline theferenc
  • Trade Count: (0)
« Reply #6 on: Mon, 03 October 2011, 15:06:25 »
Yup. It's right next to Lake Oswego, heading south on I5 from Portland.
Offline SmallFry
  • Trade Count: (0)
« Reply #7 on: Wed, 05 October 2011, 21:47:18 »
Nvm, I jumped the gun. Apologies conveyed
Offline Mr. Perfect
  • Trade Count: (0)
« Reply #8 on: Fri, 07 October 2011, 11:38:05 »
Just throwing this out there, but are you in any way attached to that particular motherboard? We've got some 1GHz P3s floating around at work, but they are of course the 133MHz bus. On the other hand, when a machine goes, the whole thing goes, so you could have the board with ram and CPU.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline zere
  • Trade Count: (0)
« Reply #9 on: Sat, 08 October 2011, 17:45:06 »
[ Attachment Invalid Or Does Not Exist ] 28141[/ATTACH]
These are the droids you are looking for.
Sorry for the bad picture quality.
Intel (R)
i(m)(C)'00
Pentium III Costa Rica
650/256/100/1.65V
3021A141-0770 SL3XV
Unfortunately, it's only a 650 one. No idea whether it still works or not (no testrig available).
« Last Edit: Sat, 08 October 2011, 17:49:29 by zere »
Offline Mr. Perfect
  • Trade Count: (0)
« Reply #10 on: Sat, 08 October 2011, 18:42:40 »
Gotcha, yeah nothing we have is that small. Plenty of Intel mATX boards(512MB limit) and an old ABit full ATX(768MB limit), but that's it. I'll keep my eyes open though, maybe someone will dredge something out of a closet and try to use it for an intern. :doh:
Offline zere
  • Trade Count: (0)
« Reply #11 on: Sat, 08 October 2011, 19:11:38 »
I'm in GER; I can send it safely in 500g airbag, which is €3.45. Sounds awfully cheap to me, but that's what the Deutsche Post website tells me
Offline Lenny_Nero
  • Trade Count: (0)
« Reply #12 on: Sun, 16 October 2011, 07:43:32 »
The spares I found are 66mhz got by my dad many years back to up his 466/socket370 celery box it seems.
I have got one spare IBM Xseries that I got in with a job lot, I have yet to lay eyes on it since,
but it was mobo/cpu/raid/case backup for the others looking at my notes,
if it can work for you and cant make a pair with the single in my supermicro its yours.
As for the speed thing there should be no problem underclocking them the coppermines(T ?) were all 100/133mhz were they not???
I underclock my Athlon XP box all the time with speedfan when its not doing any real load.
Sorry about the time delay our phone lines got dug up/something and I have just got back on with a sub 1 MB connection :(
I hope they are going to get it back all the way ...how did we ever manage with 300/75 ?
Offline kishy
  • Trade Count: (0)
  • Eye Bee M
    • http://kishy.ca/
Re: My Tualatin Celeron for your Coppermine P3/Celeron
« Reply #13 on: Tue, 31 January 2017, 14:58:30 »
I'm going to get some flack for this, but...bump.
I shelved this project and haven't touched it since. Revisiting it now. I don't even know where the Tualatin chip is anymore so I guess consider this a WTB.
kishy.ca
