Author Topic: Bling / Bells and whistles / Excessive LEDs  (Read 11099 times)
Offline khokkanen
« on: Wed, 19 January 2011, 01:41:45 »
I admit I'm not your standard issue geek/nerd/gamer. I actually often spend more time modding games than playing them and I often accept components in my computer without modifying (overclocking) them as I don't see the need for photorealism in a computer game.
Still I wonder: why for the sake of Tapio (Finnish god of forests) does everything have to come with extra LEDs? I'd love to get a subdued LEDless gaming rig but apparently it's impossible. Even the best keyboards (and mice!) have them. And on most of them, the LEDs can't be turned off.
A good example is Antec Nine Hundred Two (the case I actually bought - and from which I intend to swap out all the LEDs eventually). Sure, I can swap out every fan with a LED for ones without, but seeing as I'm on a budget, that won't happen soon enough.
My vehement opposition to bling in all its forms (not just LEDs) comes from the fact that often enough it makes the equipment not suitable for something. In my case I have a long road of getting used to all the bling since I sleep in the same room my computer is in. Another example is a "nice-looking" case that a friend couldn't buy for work (even though the price was right) because "this isn't some LAN party". He ended up with a case about the same price but far less nice features.
Now some bright fellow might ask me why I'd want to keep my computer on 24/7. The answer is: that's what it's for. It does things even when I'm not actively using it. Amazing, no?
In my sights: Xarmor U9W
Currently use: Logitech PRO 2000, Logitech M705
Previously used: Das Keyboard II (blank keys), IBM Model M, Logitech LX5
Never ever going to use: anything by Microsoft. The OS I use only because of the games I play. Anything wired. I hate wires, cords and cables and suffer them only when no other options are available.
Offline Half-Saint
« Reply #1 on: Wed, 19 January 2011, 02:26:41 »
Keeping a computer in your sleeping room on 24/7 has more than one drawback:
1. you already mentioned this - light from the LEDs. People generally sleep better in total darkness.
2. noise. You might not register it anymore but your brain does.
3. positive ions. Serotonin Irritation Syndrome
I know this isn't really the topic but think about it anyway ;)
Cheers
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline khokkanen
Sleep
« Reply #2 on: Wed, 19 January 2011, 02:57:52 »
It's not like I have a choice if I want to keep the computer on. I live in a one-room apartment.
I've been looking for a two or three room alternative for a while without success. The rents are prohibitive. For a three room apartment it would be possible to get a roommate but I haven't come across anyone suitable/willing.
Also offtopic. There are ways to battle positive ions. I just don't bother.
I do notice that occasionally it helps to sleep a night or two windows closed and almost everything turned off - one room so fridge is also a source of annoyance as is the freezer. So whenever I unplug those two for defrosting I tend to sleep in a relative quiet (depending on my lovely neighbors).
Offline instantkamera
« Reply #3 on: Wed, 19 January 2011, 07:36:44 »
I bought a fractal define r3. nothing but a power LED, which you dont have to hook up if you dont want. There are options out there, but you have to be careful about what you purchase, as a lot of the PC modding/gaming community like really tacky ****, including LEDs galore.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline khokkanen
« Reply #4 on: Wed, 19 January 2011, 09:24:36 »
Quote from: instantkamera;280983
Fractal looks nice, except that I'd prefer a case with better cooling (at least based on the reviews I found on the 'Net). I'm looking forward to the next serious upgrade and would like not to have to buy case (and possibly PSU) again... We'll see how that pans out.
As for the tacky ****, I agree. I seriously can't understand the supposed added value of LEDs and 'unique', 'futuristic' or 'bad-ass' case ornaments/shapes.
« Reply #5 on: Wed, 19 January 2011, 09:41:23 »
That may have been for the original R2, they added an intake and exhust I believe in the R3. Or define "better" cooling.
Case 2x120 front intakes (using them). a 120/140 side(exhusting w/ a low rpm 140mm). 2X120/140 top(1 exhuast 140mm, the other is unused). 120 rear (unused, corsair H50 fan will go there). psu intake bottom(used), 120mm bottom intake(unused). This thing is a cool customer ATM, and I expect it to be cooler once I add the H50.
I dont have much of a video card though, but it exhausts into the case too, a rear exhausting double height card might be a bit of an improvement as well.
Also, the fractal is a Swedish product, I believe they are all imported into NA. Availability should be good in Europe.
The NH2 is a good case though, so really your only dilemma is the damn LEDs. If you cant replace the fans, maybe you can mod the ones it comes with?
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #6 on: Wed, 19 January 2011, 09:50:33 »
I know that my most recent case does have some interior LEDs of the type described, to show off all the extra cooling fans.
But I would love to get a computer with extra LEDs of another sort. Imagine a microprocessor chip with a documented diagnostic mode, so that you could flip a switch, slowing the computer down to a stately 100 MHz or something like that, where it used the extra bus cycles at 1 GHz or whatever to export the status of its various internal registers.
Imagine it being housed in a case and motherboard that let you see an old-fashioned gingerbread front panel while the computer was running when in that mode... not just lights for the bus, like the old Altair computer, but lights showing how the pipeline, the cache, the floating-point unit, and so on, were individually functioning.
And, of course, switches to slow it down further or single-step it.
Offline khokkanen
« Reply #7 on: Wed, 19 January 2011, 11:12:39 »
AFAIK I'd have to do some modding of the fans to turn off the LEDs on Antec NH2. There's no control for that on them.
I could be wrong. Or it could be easy to do. I just hope it came without the LEDs and let the LED-heads buy their bling gear separately (or as optional 'upgrades').
Another thing I hope would come out already is solid state fans. It would be bliss.
Offline Lanx
« Reply #8 on: Wed, 19 January 2011, 12:01:02 »
Quote from: khokkanen;281087
this?
http://www.dyson.com/fans/
Offline Lanx
« Reply #9 on: Wed, 19 January 2011, 12:20:44 »
lol dyson handvac prolly has worse amazon reviews since it only lasts 6mins (in my experience i get 8-9mins).
Still there isn't a better way to clean up dog fur in a car imo.
« Reply #10 on: Wed, 19 January 2011, 12:25:38 »
I have a dyson vac (DC33 upright). ****ing wicked.
Offline Arc'xer
« Reply #11 on: Wed, 19 January 2011, 12:46:05 »
Blingless bling.
Soldam Windy case
Some of the most expensive cases.
Offline khokkanen
« Reply #12 on: Wed, 19 January 2011, 13:51:57 »
Quote from: Lanx;281109
this?
No. Besides, that isn't solid state.
What they have is: http://www.ventiva.com/
If only they would make the technology available as consumer products...
Offline PikachuDX
« Reply #13 on: Fri, 21 January 2011, 07:20:58 »
GJ'uy3{h3aVcM%B~^JcH7f$1Bg=#SN}{NLXw]cP5Y(p#z_r{t8
« Last Edit: Tue, 20 June 2023, 05:38:15 by PikachuDX »
Offline khokkanen
« Reply #14 on: Fri, 21 January 2011, 07:40:15 »
Quote from: PikachuDX;282203
On the LED subject, my PC has 0. I've disconnected the power + HDD LED, my one fan is a Scythe S-Flex (in PSU), and I've put tape over the tiny little mobo LED. :)
Excellent. I never connect any leds if I don't absolutely have to. Mobo LED I usually let be because it isn't visible. Now that I'm getting a case with a window it might require a bit of tape, though.
Offline db_Iodine
« Reply #15 on: Fri, 21 January 2011, 07:57:39 »
Quote from: instantkamera;281047
The only difference between Fractal Design R2 and R3 is that the R3 has a reset button and R2 doesn't.
[SIGPIC][/SIGPIC]
Offline PikachuDX
« Reply #16 on: Fri, 21 January 2011, 08:27:17 »
Bs}^oH^k&Ex))A4u$J6'$F;zm[1%R{&0Y'#nqJQU~)WV-C8Jy,
« Last Edit: Tue, 20 June 2023, 05:38:50 by PikachuDX »
Offline khokkanen
« Reply #17 on: Fri, 21 January 2011, 08:42:16 »
Quote from: PikachuDX;282217
I was thinking of desoldering it at one point, but I thought that's be a bit too anal.. :p
Perhaps a little... Though I'm considering the same for the stock fans that come with Antec NH2 I ordered. They have super-annoying LEDs...
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #18 on: Sat, 22 January 2011, 19:13:49 »
Here's how to get a fancy gaming computer without the stupid LED's.
Offline Lanx
« Reply #19 on: Sun, 23 January 2011, 00:21:44 »
some mobo's have built in LED's now that + hatred of LED's in computer and window= sadface.
« Reply #20 on: Sun, 23 January 2011, 08:37:17 »
Quote from: db_Iodine;282211
So it is.
I can't see how the cooling could be considered inadequate...
Offline khokkanen
« Reply #21 on: Sun, 23 January 2011, 10:52:31 »
Better is always comparative. Compared to NH2, for example, Fractal doesn't have that good of a cooling. At least based on reviews - I have no personal experience one way or the other.
And no, I had not even heard of the Fractal before this. Can't find it in any Finnish webstore either. Though it might be that I'm not up-to-date on the latest "secret super-modder/uber-gamer" haunts...
« Last Edit: Sun, 23 January 2011, 10:58:32 by khokkanen »
Offline db_Iodine
« Reply #22 on: Sun, 23 January 2011, 12:19:10 »
Quote from: khokkanen;283330
Here you go.
I wouldn't worry about temps in this case. Just add one or two more fans and everything stays very cool.
[SIGPIC][/SIGPIC]
Offline khokkanen
« Reply #23 on: Sun, 23 January 2011, 13:25:16 »
Huh. How did I miss that? Anyways, bit late as I already ordered Antec NH2.
Meh. I'll know the next time. I ordered the computer from here: Beesting. Somewhat cheaper than Jimm's and no shipping as I can go pick it up.
Offline quadibloc
  • Layout Fanatic
« Reply #24 on: Sun, 23 January 2011, 14:15:04 »
I know that when I decided to put myself together a new system about a year ago, the most reasonably-priced choice conveniently available was a gamer-style case. But I don't have it in my bedroom, nor do I have it on all day - and the extra lights have a useful safety function, warning me if any of the fans fail.
Sadly, I couldn't use it for its intended purpose - the available downloads for using the video card for math require one to own a recent copy of the suite including Microsoft Visual C++, if I understand the requirements correctly. So I haven't used it much, my old computer - not that old, having an AMD 64 chip in it - having plenty of oomph for web surfing.
By the way, you wouldn't happen to know if Laila Kinnunen, Katri Helena, or one of the other Finnish recording stars of that era ever did a Finnish-language cover version of You Don't Own Me?
Offline khokkanen
« Reply #25 on: Sun, 23 January 2011, 14:36:49 »
Sorry, not really my kind of music... I guess it's possible but wouldn't know how to go about checking it out.
Offline quadibloc
  • Layout Fanatic
« Reply #26 on: Sun, 23 January 2011, 15:05:30 »
Quote from: ripster;283481
I thought the era of Finnish Pop music was Finished?
Apparently not.
This performance dates from 1997:
although, arguably, one could claim this was nostalgia and not pop.
This one is from 2001:
apparently a cover of Helloween's hit "Power".
And here's something by a group called Tiktak,
showing that the Finnish musical scene is still full of energy and life.
Although the guitar is going quite strongly there, I think it squeezes in as pop because the group is singing on key.
This is definitely recent pop music; the artist was active as recently as 2008, apparently, if the mention of that date in her Finnish Wikipedia page is indicative of activity:
Here's something not in the genre of pop music, and not quite so recent either. I don't think I'll need to identify the song, as the melody should be instantly recognizable (except for those before whose time it was):
« Last Edit: Sun, 23 January 2011, 15:28:30 by quadibloc »
Offline db_Iodine
« Reply #27 on: Sun, 23 January 2011, 16:22:07 »
This is what I dance to every Friday.
RIP Tony.
[SIGPIC][/SIGPIC]
Offline EverythingIBM
« Reply #28 on: Sun, 23 January 2011, 16:49:25 »
Quote from: ripster;281039
My eyes.  It BURNS!
That case is too tacky.
Quote from: Half-Saint;280914
Cheers
I've actually found it quite calming having a quiet computer running while I sleep.
« Reply #29 on: Sun, 23 January 2011, 18:07:47 »
I don't have any electronics set up  in  my room, except for some old  1970's digital alarm clock. I  keep my  TV and  audio equipment downstairs in the living room,  and the computers  go down  in the bomb shelter.
