Author Topic: Strange keys in G80  (Read 2526 times)
Offline Leonidas
Strange keys in G80
« on: Wed, 19 January 2011, 14:22:10 »
Hi,
I just bought a G80-3000LSC, as my first mechanical keyboard. But I noticed some really odd things:
  • Some keys are nonclicky, especially the v key
  • Some keys feel different, less noisy (both Enter, Backspace, Numpad+)
I don't know whether that's normal for this kind of keyboard, I can try recording videos to demostrate the issue. Is this normal for this keyboard or did I get a faulty one? In the latter case I'd return it.
Apart from that, I have to admit that I like the look of the keyboard and I really like the sound. Now if only all keys were clicky...
Offline bugfix
Strange keys in G80
« Reply #1 on: Wed, 19 January 2011, 14:23:27 »
Sounds faulty.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline itlnstln
Strange keys in G80
« Reply #2 on: Wed, 19 January 2011, 14:27:02 »
I assume you have a keyboard with blues.  It might take some "breaking-in" to get the clickiness right on all your keys.  The blue switch is somewhat complex, and the slider that creates the clicking sound might need to loosen up a little.  Also, blues can be susceptible to dust, even on new keyboards.  Taking and air duster and blowing out the inside of the switch might help, too.
Offline laden3
Strange keys in G80
« Reply #3 on: Wed, 19 January 2011, 14:39:10 »
Quote from: Leonidas;281234
they are larger keys with stabilizers :rolleyes:
I rrrove brrracks.
Offline itlnstln
Strange keys in G80
« Reply #4 on: Wed, 19 January 2011, 14:42:18 »
Quote from: laden3;281260
This.  The Cherry stabilizer system is a little different than the ones typically used in other keyboards.  Many people prefer it, but it can cause a slight change in keyfeel and sound.  I don't notice it on my Cherry brown 'boards, but I can see where it might make a difference on a Cherry blue 'board, though.
Offline Leonidas
Strange keys in G80
« Reply #5 on: Wed, 19 January 2011, 15:03:53 »
Thanks for your answers. So my second problem is probably explained. I'm coming from a membrane board where all keys felt the same. I'll try to "fix" the v key and keep you up to date whether that issue went away. I really hope it is just some "breaking-in", neccessary. I guess I'll be typing v like mad the next days.
Offline sixty
    • http://deskthority.net
Strange keys in G80
« Reply #6 on: Wed, 19 January 2011, 15:05:47 »
Might be some dust in the V key. If you have a can of compressed air:
* Take off keycap
* Push stem down with a ballpen or something while spraying compressed air into the switch (make sure to be quite far away, you don't want moisture in the switch)
Offline Lanx
Strange keys in G80
« Reply #7 on: Wed, 19 January 2011, 17:01:58 »
the switch mechanism in the blue stem is probably stuck, do tricks to unstick it, some have said compressed air right into the blue stem helps.
If you find that the big keys with stabilizers feel different, make sure the stabilizers are attached. Rock the keys back and forth into the board to make sure the stabilizers are attached to the board, they feel nicer when the stabilizers are making full 100% contact.
Offline audioave10
Strange keys in G80
« Reply #8 on: Wed, 19 January 2011, 21:50:52 »
Sounds like an anomaly to me. My G80-3000 was actually very nice and no problems. Maybe shipping damage?
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
