Author Topic: Model M Keyboard HELP  (Read 1334 times)
Offline spingal
« on: Thu, 20 January 2011, 16:08:04 »
Greetings,
I took apart my Unicomp USB Endurapro (Model M) keyboard to clean the crevices.  (Almond milk all over the board, wonderful).
I have a loose 5th wire (black).  The other 4 wires (red, black, yellow, white) all have designated places but I don't recall this 5th wire being loose when I took the keyboard apart.  Any idea where it goes?
Please see my pictures if you need any visual guidance.
Spingal
Offline Phaedrus2129
« Reply #1 on: Thu, 20 January 2011, 16:09:57 »
Maybe a grounding wire? Don't know what it would ground to though. Perhaps it grounds to the backplate?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline JohnElliott
« Reply #2 on: Thu, 20 January 2011, 17:07:08 »
I agree that it's almost certainly the cable shield, but I'd expect it to end in a washer, like this:
Perhaps there's a suitable washer on one of the screws holding the controller to the keyboard, and the wire has broken off from it?
Offline Lanx
« Reply #3 on: Thu, 20 January 2011, 17:25:40 »
the washer musta been stripped off by accident?
Offline Aim Here
« Reply #4 on: Sat, 22 January 2011, 07:40:16 »
When I had to take my Customiser apart, there was some sort of a grounding wire soldered to a metal clip on the steel backplate - it looked awfully like the clip above and to the right of the Pause key in one of your pictures, though it was in a different place. There was no washer.
Offline spingal
« Reply #5 on: Thu, 27 January 2011, 12:37:51 »
Thanks for the help.  The black wire was not attached to a washer like the picture above:(
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Thu, 27 January 2011, 14:07:17 »
Quote from: spingal;285819
Then it's prolly this:
Quote from: Aim Here;282776
Said clip is seen in your first pic. Best pull it off before soldering the cable, that backplate would make a nice big heatsink.
Quote from: ripster;285829
Technically I don't believe shield should be attached at both ends anyway.  Keyboard manufacturers ignore that rule of thumb.
The connection in question seems to be the only one between shield and backplate here, so no worries about ground loops.
