Author Topic: [US] Ducky 104 key set - White on White  (Read 5761 times)
Offline bakageta
  • Trade Count: (0)
« Last Edit: Tue, 25 January 2011, 13:08:29 by bakageta »
Offline Moogle Stiltzkin
  • Trade Count: (0)
[US] Ducky 104 key sets - White on White, Black on Black
« Reply #1 on: Sat, 22 January 2011, 02:52:07 »
Is the white keys blank may i ask ??
Any close up pics of the white windowed keys.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline bakageta
  • Trade Count: (0)
« Reply #2 on: Sat, 22 January 2011, 05:11:24 »
The white keys have white text, I couldn't get a decent picture of it but it's very similar to the black keycaps. It's very subtle, you have to catch it at just the right angle to see it. I'll try to get a few close up pics for you.
(edit)
Managed to get the text to show up, kinda... Let me know if you need any other pics.
« Last Edit: Sat, 22 January 2011, 05:24:55 by bakageta »
  • Trade Count: (0)
« Reply #3 on: Sat, 22 January 2011, 05:19:02 »
thanks.
Lowyat15
15 USD discount.
  • Trade Count: (0)
« Reply #4 on: Sat, 22 January 2011, 10:52:34 »
Is it just me, or did they change the windows so that it is now molded together with the key rather than sticking outward of the key ???
Lowyat15
15 USD discount.
Offline jaynoon
  • Trade Count: (0)
« Reply #5 on: Sat, 22 January 2011, 13:34:04 »
Are these ABS or PBT?
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline bakageta
  • Trade Count: (0)
« Reply #6 on: Sat, 22 January 2011, 15:38:34 »
Quote from: Moogle Stiltzkin;282855
The window looks flush on all of the keys to me, with a bit of an edge inside to keep it in place. It looks different from the pics I'd seen with the windows half falling out of them.
Quote from: jaynoon;282917
Both sets are ABS.
Offline colorcutclarity
  • Trade Count: (0)
« Reply #7 on: Sat, 22 January 2011, 16:50:40 »
Bakageta, depending on if I get this Ducky I might be interested in these keysets if you still have them at the time.
Offline DanGWanG
  • Trade Count: (0)
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #8 on: Sat, 22 January 2011, 19:14:10 »
Any idea if the profiles match the Filco/Das 'boards?  If so, I'll take the black on black right away!
Offline bakageta
  • Trade Count: (0)
« Reply #9 on: Sat, 22 January 2011, 19:43:48 »
I'm fairly certain they do... I've got the keys off of my Filco still from cleaning them, so I'll compare a few to be sure, give me just a few.
(edit) Yep, profile seems to be identical, I compared a key from each row and couldn't notice any differences.
« Last Edit: Sat, 22 January 2011, 19:49:54 by bakageta »
Offline DanGWanG
  • Trade Count: (0)
  • Higher Standards
« Reply #10 on: Sat, 22 January 2011, 20:38:46 »
Sounds good.  I'll take the Black on Black.  YGPM =)
Offline bakageta
  • Trade Count: (0)
« Reply #11 on: Sat, 22 January 2011, 21:01:17 »
Black on black keys are sold, thanks DanGWanG!
  • Trade Count: (0)
« Reply #12 on: Sun, 23 January 2011, 02:51:58 »
Will these fit the Ducky 1008?
Offline bakageta
  • Trade Count: (0)
« Reply #13 on: Sun, 23 January 2011, 04:44:48 »
If it's the ANSI layout, yep, they sure will. It needs to have a layout like this, with the enter key taking up a single row. I've seen pics with some having the "bigass" enter as Ripster calls it, this set doesn't have that.
Offline commandercup
  • Trade Count: (0)
« Reply #14 on: Sun, 23 January 2011, 11:46:38 »
I want the white on white, sending a PM now
