Author Topic: IBM Space Saving Keyboard 1392934  (Read 4350 times)
Offline calavera
« Reply #1 on: Sun, 23 January 2011, 16:42:32 »
oh man this is going to go for a hefty price.
Offline nocturn4l3030
« Reply #2 on: Sun, 23 January 2011, 18:33:02 »
i hate you guys for posting these on here >.<  (i'm trying to acquire one)
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline lootbag
« Reply #3 on: Sun, 23 January 2011, 19:08:42 »
May the highest bidder win haha.
As much as I want one of these, I am leaning towards an 86U/87U.
SIGH
Offline theferenc
« Reply #4 on: Sun, 23 January 2011, 20:39:20 »
The realforce is MUCH smaller. And I do love me a good Topre switch. I alternate between buckling spring and topre for my typing needs. And you'll be spending about the same on either, if you want NIB.
Now, there is one distinct advantage for the IBM over the Realforce: you can change the layout of the keys to be whatever you want (within reason). The membranes are the same for all of the non-japanese layouts, so you can easily turn it into a UK or DE keyboard, or a UNIX layout, as I did.
Combined with the teensy based PS/2 converter, the remapping could even be done in hardware.
Now, if you're happy with ANSI, then this is a moot point, and it just comes down to switch and size preferences.
Offline MissileMike
« Reply #5 on: Sun, 23 January 2011, 21:07:16 »
A little late, but glad to see comptekw2k hasn't run out.  Did they always charge 36$ for shipping?
The last one went for just over 300$
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline Sam
« Reply #6 on: Sun, 23 January 2011, 21:33:13 »
Quote from: MissileMike;283656
The link in the OP is to the Canada eBay site.  Could be why the shipping is higher if it defaulted the shipping to Canada.
Offline MissileMike
« Reply #7 on: Sun, 23 January 2011, 21:41:34 »
Quote from: Sam;283666
Ah ha!  Good eye.
Offline MissileMike
« Reply #8 on: Mon, 24 January 2011, 10:10:28 »
...and in less than 24 hours we're already up to $142.50.... SSK madness knows no limits!
Offline jpc
« Reply #9 on: Mon, 24 January 2011, 11:57:27 »
What madness? They're good keyboards. :biggrin:
While any busted-up SSK can be repaired, a NIB one might also need to be repaired. Its rivets could be long gone. That's the only thing that seems possibly irrational about the price of NIB SSKs. Buyers may be assuming that NIB means new.
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline MissileMike
« Reply #10 on: Mon, 24 January 2011, 13:23:57 »
Quote from: jpc;283947
What madness? They're good keyboards. :biggrin:.
They're not good keyboards.  They're *great* keyboards!
Offline Sam
« Reply #11 on: Mon, 24 January 2011, 17:48:21 »
Good point.  Has anyone bought one of these and checked for broken rivets?  A slightly used SSK with a well-done bolt mod might actually be preferable to a brand new one where you have to spend the time to do the bolt mod yourself, and if not experienced, might damage it.
Offline kidchunks
« Reply #12 on: Wed, 26 January 2011, 05:53:17 »
Quote from: kalrykh;285018
13 busted rivets.
:eek:
Topre || BS > *
my root : kidchunks[dot]com
Offline lootbag
« Reply #13 on: Wed, 26 January 2011, 06:49:52 »
I got one from the same guy, NIB, had 13 busted rivets.
That's a bummer to hear.
Offline bigpook
« Reply #14 on: Wed, 26 January 2011, 07:04:48 »
Depends on how the feel is affected. 13 broken rivets is a bit much for me, ymmv though.
The nut/bolt mod isn't that hard to do, it is just time consuming and tedious. Use a sharp chisel, get the right nut/bolts, use a quality drill/bit and have lots of patience.
Offline Sam
« Reply #15 on: Wed, 26 January 2011, 07:22:54 »
So someone correct me if I'm wrong, if these Model M's end up with so many broken rivets by just sitting over time, then it seems the NIB premium they're commanding isn't really worth it.  Because in order for it to feel like new, it'll require a bolt mod, which by nature means it won't be NIB anymore.  So actually a nearly new keyboard with a properly executed bolt mod might even be preferable if someone got it to use it.
I was considering getting one of these, but maybe I'll pass if it's this likely a large number of rivets will be broken, and just stick to nicer used ones.  With many items, new mint versions tend to increase in value at a higher percent compared to used versions.  But if it becomes well-known that the new version degrades over time just by sitting there, I doubt they'll increase more than used ones.
Offline jpc
« Reply #16 on: Wed, 26 January 2011, 07:25:56 »
If the rest of the board is brand new, you can probably do the "lite" version of the bolt mod: drill out and bolt up only the broken rivets. This is much less work because you don't disassemble and reassemble the main assembly. Once you have the tools (dremel, drill bit, nuts, bolts, 5.5mm driver) the ersatz bolt mod takes only a few minutes.
You wouldn't be able to change out the membranes or springs, but on a NIB SSK those should be perfect already.
For those that haven't seen an M taken apart: there's nothing but solid plastic between the stud that the rivet was formerly attached to, and the front of the barrel plate. From the metal plate side, you can drill straight down into the stud and through to the barrel plate without disturbing anything important.
You'd want to remove a few keys opposite each spot you drill, so they aren't damaged. (But don't take all the keys off, because then you're sitting the board on its springs which could damage the springs.)
Offline MissileMike
« Reply #17 on: Wed, 26 January 2011, 07:57:09 »
That was just luck of the draw.  I can tilt my nib ones side to side, and I don't hear any rivets in there.
Offline Sam
« Reply #18 on: Wed, 26 January 2011, 07:59:29 »
But my understanding is that the rivets tend to break just by aging.  If this is correct, your NIB boards which currently don't have any broken rivets, may very well have major issues with rivets some years down the road.
Offline MissileMike
« Reply #19 on: Wed, 26 January 2011, 08:43:41 »
Yes, they definitely could have issues- no doubt about that.
Offline steeef
« Reply #20 on: Wed, 26 January 2011, 08:44:36 »
Think of it as an opportunity to flex your drilling muscles.
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline Sam
« Reply #21 on: Wed, 26 January 2011, 10:19:37 »
Yeah, but what about Comptek2wk?  Did he have bad karma?  Or the guy he bought it from, maybe he had bad karma.  You know, I heard bad karma has a very long half-life.  Any stored up bad karma in those rivets is bad news waiting to happen.  I do though have a super dooper bad karma zapper I'd be willing to trade you for your industrial mini and your APL mini.  Guaranteed to get rid of bad karma in your rivets.  I can't guarantee it'll help with other factors that can damage your rivets, but certainly will clean out all that nasty bad karma.
Offline keyboardlover
« Reply #22 on: Wed, 26 January 2011, 11:10:45 »
When bad karma piles up your best bet is to get on the karma payment plan. Paying off all at once can be painful!
Offline MissileMike
« Reply #23 on: Sun, 30 January 2011, 13:57:12 »
355$
Is that a record?  Will we see 400$ in 2011?
Offline lootbag
« Reply #24 on: Sun, 30 January 2011, 15:20:35 »
waaahhh~
kudos to the SSK winner.
I will stick with my lowly 1391401
& my Topres
