Author Topic: What kind of switch is this?  (Read 2952 times)
Offline NAVIWORLDINC
« on: Mon, 24 January 2011, 22:34:44 »
So... as the title implies, what kind of switch do you suspect this rare keyboard has? I found it at a rummage sale. Been meaning to post images of it for a while now, but I have been busy. I will note, that it doesn't feel near as great as my pink alps dell at101 that I have. This thing is AT connector OOOLLLDDD.
Also what do you think it is worth, trying to get rid of it via my bosses ebay account.
« Last Edit: Mon, 24 January 2011, 22:38:47 by NAVIWORLDINC »
Offline Brian8bit
« Reply #1 on: Mon, 24 January 2011, 22:36:51 »
ML switch?
Offline Nadger
« Reply #2 on: Mon, 24 January 2011, 23:15:56 »
Thread hijack eminent:
Anyone recognize this keypad to know what switch is in it?
● Logitech ♦ G600
● Noppoo ♦ Choc Mini 茶轴
● Plum ♦ 96 White / Red Switch
● Microsoft ♦ Xbox 360 Windows Controller
Offline Phaedrus2129
« Reply #3 on: Tue, 25 January 2011, 01:09:26 »
The Dell is discrete rubber domes.
The keypad is Cherry MX I believe, but make sure it's not the knock-off with rubber domes.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Ascaii
« Reply #4 on: Tue, 25 January 2011, 01:49:47 »
The dell would be hammer over membrane, it will most likely compare to the Quiettouch in feel, and that was the best non mechanical board I ever typed on. I think your chances of an ebay sale are not too great, but you might find someone interested here if you can give the board a thorough review.
Offline bakageta
« Reply #5 on: Tue, 25 January 2011, 04:02:32 »
Quote from: Phaedrus2129;284310
For $15, I'm going to pick one up and check it out, we'll see.
Offline firestorm
« Reply #6 on: Tue, 25 January 2011, 09:53:09 »
It looks like a Keytronic KB 101 Plus to me, which is a capacitive switch.
http://geekhack.org/showthread.php?t=5415
It's a nice solid board, but so-so to type on IMO.  Mine is pretty old though and was rescued from an old computer store I worked for back in the day.  It was better than the rubber domes I was typing on at the time.
« Reply #7 on: Tue, 25 January 2011, 09:59:06 »
Is there a rubber cup or a spring in-between the switch and the key cap? Is the actuation point somewhere in the middle of the stroke with mushiness below? If yes on all, then it is a capacitative foam-and-foil board.
Otherwise, I think it could be a rubber dome. The capacitative has n-key rollover. I doubt that the rubber dome does. Either way, it is not worth very much. I had one that I offered up for free on the board, and there were no takers.
Offline Nadger
« Reply #8 on: Wed, 26 January 2011, 01:18:25 »
Quote from: bakageta;284347
Nice, post an update when it comes.
● Logitech ♦ G600
« Reply #9 on: Wed, 26 January 2011, 12:08:39 »
Thanks all, I will check up on the keyboard later. Thanks for all the responses.
Offline ch_123
« Reply #10 on: Wed, 26 January 2011, 18:57:02 »
Quote from: Findecanor;284455
Pretty much this.
I have never heard of a NKRO rubber dome keyboard (by which I do not count Topres) due to the difficulty involved in soldering diodes to a plastic membrane :p
Offline bakageta
« Reply #11 on: Wed, 26 January 2011, 22:12:33 »
Good to know, glad I picked one up. It's certainly not the BEST numpad, but for the price it's hard to beat.
