Author Topic: CHERRY G80-3000 (3464HKMGB) double shots ?  (Read 7317 times)
Offline Moogle Stiltzkin
« on: Tue, 25 January 2011, 21:16:55 »
I want to harvest the control, alt, windows and menu key for my Ducky.
I just need to know whether all of these keys are double shots ?
In the anti otaku thread, someone mentioned a different cherry board that kinda have the same look, the windows keys was not double shot. This is why i want to double check on GH first.
http://geekhack.org/showpost.php?p=156685&postcount=67
I'll of course try and get the seller to give pictures behind the key caps as well to be safe.
"So long as we do not depend on the facts entirely, incomplete knowledge is better than complete ignorance."
:bounce:
Current gaming keyboard: Ducky DK-9008 with Cherry Beige/White doubleshots (Cherry Mx Brown)
For my 2nd pc: Cherry G80-1095 HAU Revision 00 (Cherry Mx Black)
Dye subbed keys harvested from NCR 3299-k440-v001 G80-3007 SAU. Casing donated to Mike.
[/FONT]
Free mechanical keyboard + other gear click here![/color]
Offline calavera
« Reply #1 on: Tue, 25 January 2011, 21:24:08 »
what happened to the groupbuy you wanted to get going? are you giving up on that if this goes through?
« Reply #2 on: Tue, 25 January 2011, 23:41:18 »
I'm using these as temporary until we get the group buy one.
I could also trade these for a beige double shot later if the opportunity arises.
Anyway i found a seller willing to sell me only just the alt, control, windows, menu keys from this keyboard.
:bounce:
[/FONT]
Offline sixty
    • http://deskthority.net
« Reply #3 on: Tue, 25 January 2011, 23:43:10 »
Windows and Menu key are not double shot. Double shot variants of those do not exist. Cherry was not fond of using double shot on pictographs and always reversed to their alternative pad printing + heat shield method as with the LED window keys.
« Reply #4 on: Wed, 26 January 2011, 00:10:00 »
Quote from: sixty;284905
Crap... i was afraid of that because someone mentioned it in the anti otaku thread. but the model they were referring to was a POS. So i guess it applies to the other keyboards as well damn :[
I guess i will pass on these black keys then. They weren't really what i wanted anyway, just desperate :p
By the way sixty, does that apply as well to the white/beige cherry keyboard for these keys ? Specifically the G80-3000H*MGB model keyboards.
« Last Edit: Wed, 26 January 2011, 00:15:19 by Moogle Stiltzkin »
:bounce:
[/FONT]
Offline sixty
« Reply #5 on: Wed, 26 January 2011, 00:44:44 »
Yes same deal. As I said, Cherry never made any "non lettered" key in double shot. Everything with an icon or pictograph on it was pad printed + heat shield. That method is enough though. I have a 15 year old G80-3000HAMDE that has seen heavy use. The windows and menu keys still look brand new. Also the way Cherry made them, they match perfectly with the other double shot keys in terms of color and contrast. So it really does not matter.
« Reply #6 on: Wed, 26 January 2011, 04:57:12 »
Problem is rip,
i am only using the bottom row from white rice's kit with Sixty's full set.
Also it's not matching color, and besides i want to wean off White Rice's kit so i can use it for another keyboard.
:bounce:
[/FONT]
« Reply #7 on: Wed, 26 January 2011, 07:23:44 »
Just got pictures from the seller.
Sixty you were right bro.
http://img508.imageshack.us/g/sdc12199.jpg/
http://img263.imageshack.us/i/sdc12200b.jpg/
:bounce:
[/FONT]
Offline keyboardlover
« Reply #8 on: Mon, 31 January 2011, 23:07:45 »
I wouldn't mind if only the windows and menu keys are not doubleshot. Does anyone know if these keys are available in white/gray?
Offline jaynoon
« Reply #9 on: Mon, 31 January 2011, 23:56:30 »
I'm ok if a couple aren't DS too. It ocurred to me that the problem with a Signature Plastics "patch kit" is the key profile (especially that space bar). It seems like these would be a closer match (albeit an expensive one).
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
« Reply #10 on: Tue, 01 February 2011, 00:07:28 »
7bit said they made the spacebar better than white rice's which had a steep recline. So should be fine regarding the spacebar.
:bounce:
[/FONT]
« Reply #12 on: Tue, 01 February 2011, 00:31:05 »
If it's cherry mx keyboard then yeah.
:bounce:
[/FONT]
Offline laden3
« Reply #13 on: Tue, 01 February 2011, 01:32:26 »
Quote from: manfaux;288118
are these MX compatible double shots too?
http://cgi.ebay.com/Cherry-MY-7000-Credit-Card-POS-Black-Keyboard-PS2-/230570873521?pt=LH_DefaultDomain_0&hash=item35af1852b1#ht_1442wt_900
Should be. Those are pretty cheap too o.o. I would avoid used double shots though, abs gets shiny. You can always use the "sort by" drop down menu to find the cheapest keyboard you can get...
You can search for g80-8200s too, I got one this morning for $80 shipped, missed one last week... NIB too. The stems of the keys on the bottom row and the caps lock are centered.
I rrrove brrracks.
Offline jaynoon
« Reply #14 on: Tue, 01 February 2011, 02:59:34 »
Quote from: Moogle Stiltzkin;288110
Oh that's good news, that was definitely my biggest complaint about the whiterice set.
