Author Topic: Question to 10 keyless users.. that use numbers often.  (Read 5116 times)
Offline mashingkeys
« on: Wed, 26 January 2011, 21:10:27 »
Currently typing on a full board; always have.  I do use the 10 key area a lot, and I was wondering what some of you use as a substitution?  I think the choc mini has a function switch for them in the main rows, but what about other boards?
The PLU ML-87 caught my attention, and it's equal to or possibly even LESS than what I was about to pay for the Rosewill RK-9000..  something about the 10keyless style is just really attractive to me, but I don't know if I'd go crazy without my numbers D:
Offline keyboardlover
« Reply #1 on: Wed, 26 January 2011, 21:15:26 »
I just learned to use the number row...it's not really that bad once you get used to it.
Offline WhiteRice
« Reply #2 on: Wed, 26 January 2011, 21:38:08 »
I realized the thing the tenkey is for. One handed keying when you're holding material in your right hand.
Offline calavera
« Reply #3 on: Wed, 26 January 2011, 21:40:02 »
I bought a numkey pad just in case but have gotten used to just using the rows above the letters so I don't really use it anymore.
Offline godofdeath
« Reply #4 on: Wed, 26 January 2011, 22:34:33 »
it feels more for if you dont have to deal with ALOT of numbers.
in the office i got a number pad on the laptop since there are a ton of transactions that must be keyed in so the number row is a pain.
those 10 keys or so makes it quicker
basically see if you like how a laptop would be without the 10 keys
Offline bakageta
« Reply #5 on: Wed, 26 January 2011, 22:49:59 »
I don't have to deal with like spreadsheets with a tenkeyless, but I'd say I use a fair amount of numbers for an average user. It really wasn't a big issue. I did pick up a separate numpad recently, just in case I need to do some serious number entry, but the ergonomics of having my mouse closer to WASD was the main reason I went tenkeyless, and I don't plan on ever going back.
Offline steeef
« Reply #6 on: Wed, 26 January 2011, 23:24:13 »
Autohotkey with Caps Lock as an Fn key. Hold down the key, and part of my keyboard becomes the numpad. Works when I need it, but usually I just use the number row.
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline Tony
« Reply #7 on: Wed, 26 January 2011, 23:57:54 »
Typists are good at typing the number row. For accountants, ten-keys is a must.
Offline Lanx
« Reply #8 on: Thu, 27 January 2011, 04:08:50 »
numrow works most of the time for me, if i have to do some heavy number action, then i'll use the nostromo which is set for numpad. But usually can just default to numrow.
Offline godly_music
« Reply #9 on: Thu, 27 January 2011, 04:44:59 »
Why you want a numpad:
1. Nethack
2. ?
3. Numbers
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #10 on: Thu, 27 January 2011, 05:40:58 »
There's nothing wrong with a separate numpad if you feel you need it. Gives you more freedom in switch choice, too. For example, not that many people prefer MX blacks for typing, but in a numpad they do a fine job.
Offline Muhi
    • http://twitter.com/darkleeroy
« Reply #11 on: Thu, 27 January 2011, 08:47:54 »
Well ultimately it depends on what you're planning to do with it. At work, I ragequit unless I have a tenkey for my laptop. At home while playing sc2, I can care less.
Accountants use the tenkey. If you're planning on typing numbers longer than six digits regularly, I'd recommend the use of the a tenkey.
Rule No. 2 - Double Tap: You think it’s dead (technically it was before you shot it), one more makes 100% sure.
Offline itlnstln
« Reply #12 on: Thu, 27 January 2011, 08:53:32 »
I work in retail and need to type multiple UPC codes quite often.  When I was using my HHKB exclusively, I bought a numpad to go with it when I was at my desk (I don't bring it with me).  That said, I don't typically buy tenkeyless 'boards.  The HHKB and the Noppoo are exceptions due to their particularly small layouts.
Offline mashingkeys
« Reply #13 on: Thu, 27 January 2011, 09:20:05 »
Thanks for all the opinions :D to be honest, I mostly use 10key for personal financing and my absurd passwords.  I don't use it all day long, so i think it'll be a welcome change.
Now the question is, do we have a faq for ordering with obook?  It seems to be the preferred way to order things overseas here
Offline bytemeavaj
« Reply #14 on: Thu, 27 January 2011, 09:32:28 »
Quote from: mashingkeys;285684
A gentleman from my thread referred me to this post:
http://geekhack.org/showpost.php?p=270934&postcount=12
I hope it helps.
I\'m a tool.
Offline mashingkeys
« Reply #15 on: Thu, 27 January 2011, 09:58:47 »
Thanks for that link.. I can find the keyboard just fine on taobao, but I can't seem to find one that is specifically mx blues.. they all seem to say blue/brown/black.
For example: http://item.taobao.com/item.htm?id=9022132476
Do I specify that preference with obook?
Offline bytemeavaj
« Reply #16 on: Thu, 27 January 2011, 10:02:44 »
Quote from: mashingkeys;285698
I can't say for sure but that looks like it's offering two choices, black and brown.
If you hover the 茶轴, you can select it, which makes it brown switches. However, I'm not completely sure so don't trust my word on it.
I'm sure someone more experienced can jump in with their advice.
Let us know what you find out!
I\'m a tool.
Offline bakageta
« Reply #17 on: Thu, 27 January 2011, 15:33:39 »
Yep, bytemeavaj is correct, the two options listed are black and brown. You'll need to find a listing that has "青轴" as one of the options. To order, just email Obook the link to the item and something like "青轴 option" or whatever the specific option says. For example, this link has an option for blues, if you're wanting a black keyboard with legends, or this link if you're wanting a blank white one...
Offline Daniel Beaver
« Reply #18 on: Thu, 27 January 2011, 16:52:50 »
That is a very handy feature of the tenkey, one that I miss.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline mashingkeys
« Reply #19 on: Thu, 27 January 2011, 20:21:20 »
Quote from: bakageta;285924
thanks so much! :D I sent obook my e-mail, we'll see what happens.
Offline bakageta
« Reply #20 on: Thu, 27 January 2011, 20:58:10 »
If you're wanting it quickly, I suggest going with the default EMS/TNT shipping option. It ended up being overnight delivery for me, and I believe a few others, despite their estimate of 1 week delivery. The keyboard was actually in my hand before the tracking number was working on the website.
Offline mashingkeys
« Reply #21 on: Fri, 28 January 2011, 08:58:56 »
Hmm, so usually it seems people get a quote within a few hours from obook, right?  I got an e-mail back just alerting me about potential delays through Feb 8th (which I understand due to the holiday), and it said
Thanks for your email and nice to meet you.  I refer you to your request on purchase from Taobao or China per attached.
We will provide you a more detailed quotation once ready.  Meanwhile, you may refer to information below for details of our services.
So I'm guessing I just sit back and wait for a price?
