Author Topic: Model M double tapping?  (Read 2766 times)
Offline hglazm
« on: Fri, 28 January 2011, 22:15:26 »
So I've got a model m.  Bought it off a friend who had it in his garage for $30.  Worked fine for about 6 months, but recently when I hit the r key it will sometimes double-tap it even though I've only hit it once.
I've tried multiple times cleaning it out with a q-tip and rubbing alcohol, and this usually makes it go away for awhile.  But it always comes back.  Any ideas on what the problem might be?
Offline Arcanius
  • Buckling Spring Lover
« Reply #1 on: Fri, 28 January 2011, 22:21:12 »
I had this problem and the spring was loose on the hammer. It's not really trivial to fix. Take something that can grab the spring and while twisting it... clockwise? push it further down.
DON'T do it until somebody confirms the direction of rotation. :/
-edit. Confirmed that spring goes on clockwise.
Also, maybe you broke a couple of rivets that were keeping the membrane close to the hammer, this might be an issue as well.
« Last Edit: Fri, 28 January 2011, 22:36:14 by Arcanius »
Offline Mr. Perfect
« Reply #2 on: Sat, 29 January 2011, 00:37:22 »
Nice improvised tool.
Now, have you got a picture of a Model M with the caption "I'd tap that!"?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Soarer
« Reply #3 on: Sat, 29 January 2011, 08:28:12 »
My weapon of choice is the SevenDeadlyCocktailSticks.
The middle stick slides in to compress the spring, and has a concave tip to stop it slipping off the hammer.
Offline theferenc
« Reply #4 on: Sat, 29 January 2011, 09:09:16 »
Oh, now that's slick, Soarer.
Offline Soarer
« Reply #5 on: Sat, 29 January 2011, 10:41:46 »
Very easy to make, and the sticks I had were just the right size, 2mm - I don't know if that's an industry standard size for cocktail sticks!
The dimple in the end was made with a 2mm drill bit, using the tube of six sticks to keep it aligned.
