Author Topic: Windows Key Size Confirmation  (Read 1777 times)
Offline Snoogle
« on: Fri, 28 January 2011, 22:34:06 »
So I'm on a Mac, and not about to relearn my option/positioning for a windows keyboard layout. I'm just gonna flip them around under my keyboard preferences. Probably going to use the non printed bubble key link
On the Leopold model that elitekeyboards will eventually stock, will the windows key and alt key be the same size? So I can swap them?
Offline Arcanius
  • Buckling Spring Lover
« Reply #1 on: Fri, 28 January 2011, 22:43:29 »
They will be. The alt key is 1.5 regular keys wide, the same as a Windows key. This sadly means your spacebar becomes smaller. :(
But yes. they'll be fully swappable, like on Filcos, for that matter.
Offline Snoogle
« Reply #2 on: Fri, 28 January 2011, 23:21:07 »
Thank you for the quick reply. Would kill for an apple key replacement.
Quote from: Arcanius;286738
I jump on the Filcos bandwagon, if there were easily accessible to me.
