Author Topic: Mac Pro line-in accessory  (Read 2468 times)
Offline Snoogle
« on: Sat, 29 January 2011, 01:11:53 »
Iono if this exists or not, but I'm looking to use my line-in port on my Mac Pro and it has an unpowered port.
Is there an accessory that'll power my unpowered port?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Sat, 29 January 2011, 11:55:23 »
A line-in, by my understanding, is a line-level analog stereo input. No device for use with this requires it to supply power.
If the sound chip used is of the HD Audio variety, it should allow routing the microphone input to the input jack. That one normally supplies a low DC voltage for powering common electret mics. The input will be mono and much more sensitive then, however.
It might be helpful to mention just what you intend to accomplish.
Offline Snoogle
« Reply #2 on: Sat, 29 January 2011, 18:57:48 »
I'm not trying to do much.
I have a simple gaming headset with a mic.
Offline keyb_gr
  • Cherrified user
« Reply #3 on: Sun, 30 January 2011, 15:20:59 »
Quote from: Snoogle;287037
Switch the input to mic and you should be good.
(Normally when notebooks have only one kind of input, it's a mic-in. A line-in suggests that there's a HD Audio codec inside that allows rerouting.)
