Author Topic: is there a way to make the CapLock light stay on?  (Read 2627 times)
Offline manfaux
« on: Sat, 29 January 2011, 20:08:43 »
is there a way to make the Caps Lock light stay on?
the actual caps lock has to stay off of course.
Offline Cyanide
« Reply #1 on: Sat, 29 January 2011, 20:11:30 »
Just type in all caps, its what the pros do ^_^ ♥
Offline TexasFlood
« Reply #2 on: Sat, 29 January 2011, 20:12:33 »
Quote from: manfaux;287057
is there a way to make the caps lock light stay on?
The actual caps lock has to stay off of course.
Quote from: cyanide;287060
just type in all caps, its what the pros do ^_^ ♥
wow, you read my mind!
Offline manfaux
« Reply #3 on: Sat, 29 January 2011, 20:14:14 »
i want an iNVERSE CAp s loCk on my board,
capS LIghT on = capS lock oFf
cAPs liGht off = CAps LOCk on
Offline manfaux
« Reply #4 on: Sat, 29 January 2011, 20:59:29 »
Quote from: ripster;287067
Autohotkey.  Link.
Or bruteforce it with a small microcontroller.  I've seen a ATTiny13 used for this kind of thing.
If i were a girl I'd give you a kiss on the cheeks.
Offline Pylon
« Reply #5 on: Sat, 29 January 2011, 21:05:45 »
Build one of those NOT gates and wire it to the LED.
http://en.wikipedia.org/wiki/NOT_Gate
Offline Soarer
« Reply #6 on: Sat, 29 January 2011, 21:07:29 »
Sledgehammer to crack a nut, since one transistor would do!
OK, and probably one or two resistors as well.
transistor switch :-)
Offline Soarer
« Reply #7 on: Sat, 29 January 2011, 21:31:46 »
Good for him! Not quite what manfaux asked for though. One puny transistor is hung well enough with three legs.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #8 on: Sun, 30 January 2011, 02:50:19 »
How on earth do you come up with this stuff rip? It's a talent.  XD
To the OP-
Edit:
Crap! I just saw that you wanted the inverse of what the light already did. Caps "on" when light off, nevermind.  =S
« Last Edit: Sun, 30 January 2011, 02:53:14 by clickclack »
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
