Author Topic: Choc Mini vs Plu M-87  (Read 6001 times)
Offline mashingkeys
« on: Sun, 30 January 2011, 22:02:10 »
About to make my first ten keyless purchase here, and before I did I wanted to get some opinions.
The noppoo choc mini seems to be pretty highly regarded with it's fit / finish, overall value for price, etc. and is roughly $10 usd more than the plum board.  It's also more compact.
The plum is slightly bigger / more spaced out with a full insert, home, etc. section but what I've been able to dig up in the means of a complete review have been very very very scarce.
I like how they both look, but if there's a difference in keycap quality or anything else that I might be missing (I'm aware that the noppoo currently doesn't function properly on Macs), please let me know :D
Any personal experiences, etc. are greatly appreciated!  Thank you!
Offline manfaux
« Reply #1 on: Sun, 30 January 2011, 23:44:46 »
I think if you can live with the Choc Mini's layout, go for the Choc. I think the choc mini has got better keycaps and build quality overall.
Offline Orphagn
« Reply #2 on: Sun, 30 January 2011, 23:45:36 »
Choc Mini all the way!
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline mashingkeys
« Reply #3 on: Mon, 31 January 2011, 00:03:56 »
Quote from: manfaux;287609
I didn't notice anything particularly bad about the layout?  a little compacted with the page up / down, etc. keys, but nothing too huge for me off the bat.
For the most part, I'm used to typing on a macbook keyboard
The only dislike with the choc mini are the colored media functions, but that's pretty minor
Offline manfaux
« Reply #4 on: Mon, 31 January 2011, 00:25:30 »
Quote from: mashingkeys;287617
well then the only thing you should be aware of is that the choc mini wont work under mac os.
Offline RiGS
« Reply #5 on: Mon, 31 January 2011, 01:11:27 »
Quote from: Orphagn;287610
Which one do you like better your new Choc mini with browns or the Cherry g80-3494 with reds?
Offline Orphagn
« Reply #6 on: Mon, 31 January 2011, 01:29:53 »
Quote from: RiGS;287631
I like the linear feel of the Reds, but the Choc's Browns are very light and when i'm typing I don't feel the tactile bump except for the spacebar.
I've been using the Choc Mini since it came in because its nice and compact and the 3494 is a bit big for my small desk.
If they made a Choc Mini with Reds i'd probably buy 2 up immediately.
As much as I like the 3494, the Choc's Browns are light enough for me to not mind the small tactile bump.
I like both keyboards equally, but right now i'm liking the Choc Mini more due to it's small size.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline RiGS
« Reply #7 on: Mon, 31 January 2011, 01:42:24 »
Quote from: Orphagn;287636
Maybe modding an mx black choc mini with looser springs (either brown spring or sixty's smooth spring) would be a better option for you.
Offline speakeasy
« Reply #8 on: Mon, 31 January 2011, 01:48:54 »
I had the same conundrum last month, but I'm pleased that I went with the choc mini. I may purchase the PLU ML-G3000 in the future if they come out with a white version (though, there is the fullsize Noppoo Choc in white as well), but right now I can't imagine the PLU ML-87 being better unless you have a tough time adapting to the new layout, or you like the cosmetics of the PLU better.
The black ML-87 has POM keycaps which is the same as the Choc Mini, but the white version (which is the one that most people here seem to be getting) are ABS if I remember correctly. The ML-87 also has issues past 2KRO which is what ultimately led me to choosing the choc mini, but that may not matter for you. I think the ML-87 looks nicer cosmetically, though the choc mini looks better in person than it does in pictures IMO.
[sigpic][/sigpic]
PiaNoppoo Choc Mini 茶轴
PUNCH THE KEYS FOR GOD\'S SAKE!
Offline Orphagn
« Reply #9 on: Mon, 31 January 2011, 02:44:34 »
Quote from: RiGS;287637
I would've already put my Red plungers and springs in if the Choc Mini wasn't plate mounted :P
I don't want to desolder 2 boards and resolder again.  Plus, I don't even know how to solder.
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline RiGS
« Reply #10 on: Mon, 31 January 2011, 03:30:06 »
Maybe it is a good time to learn how to solder or to find someone that is comfortable with soldering.
I would recommend you buying this http://cgi.ebay.com/WELLER-SOLDER-STATION-WESD51-50-WATT-DIGITAL-ADJUST-NEW-/380233685592?pt=LH_DefaultDomain_0&hash=item5887b19a58 solder station.
It is not that difficult.
Offline kidchunks
« Reply #11 on: Mon, 31 January 2011, 07:28:27 »
Plu M-87!
If you don't care about the kro issues (which isn't as bad as many state).
« Last Edit: Mon, 31 January 2011, 07:37:23 by kidchunks »
Topre || BS > *
my root : kidchunks[dot]com
Offline iMav
  • geekhack creator/founder
« Reply #12 on: Mon, 31 January 2011, 07:54:45 »
I've owned both (the choc mini only briefly).  The choc was great, except for the fact that I wanted to use it on a Mac.  I currently have the PLU 87 and really like it.  The white is really nice looking, and I haven't had any issues with the fit/finish of the 'board...it's quite solid.
As long as you aren't a Mac user, you can't go wrong with either...If I was to suggest one over the other, I would say the PLU-87...but that is mainly because of the OS compatibility issue.
Offline itlnstln
« Reply #13 on: Mon, 31 January 2011, 09:10:37 »
Personally, I would go for the Choc Mini over other tenkeyless 'boards.  They have, essentially, the same keys in a more compact layout and the keycaps are beastly.
