Author Topic: Goupil G80-1861 stem & spring swap!  (Read 6506 times)
Offline Half-Saint
« on: Mon, 31 January 2011, 12:33:58 »
I bought the board recently thanks to a friendly geekhacker who published the link in the Great finds forum. Anyway, I liked the board but I wanted to see, if I could do the stem and spring swap. To do that, I bought a donor G80-1000 with Cherry blues and here are the results!
Along the way I also enhanced CeeSa's method of popping-open Cherry switches (see vid). All you need is a flat-head precision screwdriver.
I'm gonna use the keycaps from 7bit for this board.
« Last Edit: Tue, 01 February 2011, 00:20:13 by Half-Saint »
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline Ascaii
« Reply #1 on: Mon, 31 January 2011, 14:29:22 »
looking real good!
So thats what you wanted the 1000 for^^.
I love compact boards with blues. Maybe i should do this to one of my 1800s as well.
Offline Half-Saint
« Reply #2 on: Tue, 01 February 2011, 00:41:54 »
Thanks! I added a how-to video for the stem swap, check it out! :)
With this method you can easily swap the stems for switches with stabilizers as well.
Cheers
SainT
[SIGPIC][/SIGPIC]
