Author Topic: (.de) IBM Terminal Model F  (Read 2247 times)
Offline krstf
« on: Tue, 01 February 2011, 10:22:01 »
Offline Soarer
« Reply #1 on: Tue, 01 February 2011, 11:06:12 »
Is that definately an F?
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #2 on: Tue, 01 February 2011, 11:25:34 »
Not 100% unless I look at the back. But it looks nearly identical to my Terminal F, connector as well.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline krstf
« Reply #3 on: Tue, 01 February 2011, 12:54:37 »
I'm pretty sure it is an F - if the selling information is correct.
Seller states that it is manufactured in 85, and that it weighs around 5 kilos. Also the square silver label on the right side indicates that it is an F...
Offline msiegel
« Reply #4 on: Tue, 01 February 2011, 12:59:45 »
it also has "hat" keycaps on the bottom row... common on Fs but not on Ms
Offline Soarer
« Reply #5 on: Tue, 01 February 2011, 13:15:44 »
Hmm. I have a Terminal M (3270PC) which looks very similar (apart from the key legends, of course!), but it has a non-standard label so I don't know its birth date.
It was in a sorry state, poor thing...
Offline krstf
« Reply #6 on: Tue, 01 February 2011, 13:43:09 »
Quote from: Soarer;288396
I hope it is better now. It does look very similar indeed.
How much does it weigh? From what I've gathered the F should be quite a bit heavier than the M.
Offline Soarer
« Reply #7 on: Tue, 01 February 2011, 13:55:19 »
Quote from: krstf;288408
Much better now, all clean and no missing keys or springs :-)
Mine weighs just over 2.8 kg. So unless the seller is just guessing the weight, it is likely to be an F on that basis.
