Author Topic: Rubbing Alchohol  (Read 2595 times)
Offline hemo796
Rubbing Alchohol
« on: Thu, 03 February 2011, 03:31:10 »
Anyone else have issues using isopropyl on their keyboards? Ive been using it to clean my majestouch - cleaning the keys im fine, but whenever I use it on the frame it always leaves a black residue on the cloth, no matter how many times I try and clean the same spot. Im just wondering if its safe, or is it possibly corroding the plastic? :s
Offline REVENGE
Rubbing Alchohol
« Reply #1 on: Thu, 03 February 2011, 03:36:47 »
"Isopropyl alcohol attacks some plastics, rubber, and coatings."
This is just a quote pulled off of some MSDSs on the web, there's some debate over whether or not you should use it to clean plastics.
« Last Edit: Thu, 03 February 2011, 03:42:29 by REVENGE »
Offline HaiiYaa
Rubbing Alchohol
« Reply #2 on: Thu, 03 February 2011, 03:46:53 »
its probally eating your coating but i had no issues with my steelseries and zowie keyboards as long as i just rub the keys fast and the cloth is not completely soaked in isopropryl
Offline itlnstln
Rubbing Alchohol
« Reply #3 on: Thu, 03 February 2011, 10:00:48 »
I use Lysol wipes.  They haven't damaged any of my keyboards (yet).
Offline itlnstln
Rubbing Alchohol
« Reply #4 on: Thu, 03 February 2011, 10:08:39 »
Huh?
Offline stuiees
Rubbing Alchohol
« Reply #5 on: Thu, 03 February 2011, 18:09:43 »
ouch... hope it didnt smear too much.
I like Topre!
woody
  •  Guest
Rubbing Alchohol
« Reply #6 on: Fri, 04 February 2011, 07:52:38 »
I get "Spiritus Aethylicus" from Pharmacy. That should be about 9 parts Ethanol and 1 part distilled water solution. Being used for dermatological treatment, I guess it's pure.
Offline Megaweapon
Rubbing Alchohol
« Reply #7 on: Fri, 04 February 2011, 15:46:14 »
So wait...we could safely use some high percentage grain alcohol to clean our keyboards with?
Interesting...
Ancer Research Groop DFK191ABA11 IBM Model M13 Part 92G7461 (white) Rosewill RK-9000
Matias Tactile Pro 3 Apple Extended Keyboard II (ALPS)
Rosewill RK-9000I
Offline itlnstln
Rubbing Alchohol
« Reply #8 on: Fri, 04 February 2011, 16:03:01 »
You hobo-ing it up in that pic, rip?
