Author Topic: Problems with ducky's layout  (Read 2611 times)
Offline Jimmeh
« on: Fri, 04 February 2011, 05:36:35 »
Hey,
I bought my ducky dk-1008 one month ago and have liked in all aspects, but i have started to miss the >-key i had when i used a keyboard with a finnish layout. Is there anything to be done? Thanks.
Input devices: Keyboards: Ducky DK-1008 (blue switches), Cherry G81-7000 (Cherry MY-switches)
Mice: Logitech G5
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Fri, 04 February 2011, 07:10:04 »
Looks like you should have gotten a board in some ISO layout instead. You may want to check whether The Keyboard Co. still has some Filcos in Swedish/Finnish layout in stock.
Offline db_Iodine
« Reply #2 on: Sun, 06 February 2011, 08:13:33 »
My best advise is to remap the <>| key to some other key that you don't use that often. For example Caps lock - There's a key that's basically useless IMO and would be close to where the original <>| key is in Fi layout normally.
« Last Edit: Sun, 06 February 2011, 08:15:58 by db_Iodine »
[SIGPIC][/SIGPIC]
Offline ranm
« Reply #3 on: Sun, 06 February 2011, 08:56:38 »
Quote from: Julle;290689
Jimmeh, you should probably activate both Finnish and US international keyboard layouts on your OS. Then whenever you need the characters on the 88th key, you just switch to the US layout, where those characters are more easily accessible anyway.
I don't remember how this works on linux, but on Windows switching between installed layouts is as easy as pressing Alt+Left Shift. On both systems the keyboard shortcut is customizable, IIRC.
Imho I think that it is pretty overkill to have to use a key combo to access the < and > keys. When programming especially it becomes very counter-productive.
I suggest you wait till the end of this month to get a Filco from the keyboard company! Or maybe wait for  (when and if) Ducky to produce international keyboards. =/
Offline Agiel
« Reply #4 on: Sun, 06 February 2011, 11:10:48 »
Or you could use MSKLC or AutoHotkey or something similar and map '<' to Alt Gr + ',' , '>' to Alt Gr + '.' and '|'to Alt Gr + '-' . That's what I'll do when I get my Filco some time early next week :).
I was going to wait for the Swedish layout (keyboardco says end of February for the Tenkeyless), but the more I thought about it, the more I started to dislike the ISO enter key. ANSI really does make more sense and you only lose one button, which you can remap to anywhere you like anyway.
[SIGPIC][/SIGPIC]
